P1000 New Fox shocks, how well will they work with my lift?
A
austincrow
Houston TX
When I bought my pioneer it had the highlifter 3” lift and 30”mudlites. I would prefer to remove the lift but worried my 30” tires would rub the fenders. I just ordered my fox qs3’s and I am worried the lift is going to stretch those shocks by 3” more and I will lose ride quality.
1.a. Will the lift I have work with the standard Fox shocks or do I need to uograde springs?
1. should I remove the lift, will it drastically improve my ride?
2. will 30” tires without stretched a arms rub every time I hit a bump?
3. if I upgraded to streched a arms in the front would it be enough if I remove the lift? Or would I need to address the back also?
thanks for any input!
Reactions: TxDoc and Lady01
jtb33
jtb33
41
158
AZ
I'm wondering the exact same things. Did you already do this?
Reactions: Lady01
ToddACimer
ToddACimer
Pioneer 1005-2
3,804
16,187
Oshkosh, Wi
With stock a-arms you likely can't add enough preload for a good ride and tire clearance. With a bracket lift and fox shocks the ride will be stiffer than with offset arms and no lift.
Your best bet would be to run offset arms and no lift for good ride quality with 30" tires. Running fox shocks and stock springs will likely be fair stiff in the rear despite sagging ride height. Many forum members here have replaced the fox springs to improve ride quality and maintain ride height
Reactions: Lady01
P1K5Dave
P1K5Dave
2,318
8,632
Petoskey, MI
The highlifter won't "stretch" your new shocks but it is (by definition) a decrease in ride quality because it changes the geometry of your shocks, making them run more vertical (like pogo sticks) instead of angled like they should be.
You're in for big ride improvement with the foxes, but the bracket lift would be working against you.
So, forward front arms will get you the clearance you need for the 30s, and you should be good in the back with some preload (I think - I haven't run this...)
Preload is more effective on the foxes in the front than it is on the rear, however. Stay tuned, I'm going to do a write-up on that based on my work last night.
Reactions: Lady01
