P500 New Honda motor for Pioneer 500
Luno
Luno
11
10
Memramcook
Hi guys,
I'm wondering if a brand new motor in the crate can be bought from Honda..... or can you just rebuild it?
thanks
Martin
Bastardchild
Bastardchild
1,978
7,252
Orange Heights, fl
Found this with a quick google search. I imagine if youre handy with some wrenches you can rebuild one for way less than this though, no matter whats wrong with it. There is tons of engine parts on ebay also. Engine case's and cranks, top end rebuild kits, etc...
Screenshot 20210104 115455 Samsung Internet
Reactions: Backwoods and CID
5,759
26,447
Almost anything can be rebuilt but it's frequently cheaper to find a used motor from a totaled 500. (dependent of course on why you're rebuilding)
F
Fischer
209
321
The woods
Hi guys,
thanks
Martin
Was the engine just high miles or did something unusual happen?
Reactions: CID
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Like Fischer said, what happened? If smoking from miles/hours, simple fix, but water then you have additional work ahead of you
Keebler
Keebler
273
918
St Charles, Mo
Is the P500 engine the same engine used in either the Foreman or Rubicon?
906UP
906UP
15,061
143,164
da Yoop
Yup, for the most part as long as it's an electric shift model
The gears I put in to increase speed/lower trail rpm are from a Rancher 420. The 520 cyl/piston I used to rebuild mine was ordered for a 2020 Foreman 520 only because the 2021 P520 parts schematics weren't available yet.
Jerryg
Jerryg
12,272
96,759
NEPA
Replacement Engines for power equipment are available as long as the emission laws have not changed.
I would be interested in knowing this as well.
Jerryg
Jerryg
12,272
96,759
NEPA
BTW, I am sure a rebuild would be less expensive unless there was catastrophic damage.
Reactions: Bastardchild
The Green Goat
The Green Goat
2,438
17,957
What gears did you change out? Is it possible to change just the 5th gear set to taller gearing so one can maintain the low end but get more top end out of them? Or is it an all-or-nothing sort of thing?
906UP
906UP
15,061
143,164
da Yoop
The final drive gears for the trans. Here's the link to the thread about it.
