New owner of p1000 differential question
lukpy8810
lukpy8810
91
203
Minnesota
So I have a new to me 2018 p1k with about 4700 miles on it. I understand that when you place the transmission in park, regardless of lever position, it will place the rear differential in lock. My question is then I start the machine back up, I'm in turf mode, and place the machine in gear(forward or reverse) and go the start moving I will feel and hear the rear diff pop\clunk and learch when I make a turn or back up and turn around. After that the machine runs and drives normally. Is that the rear diff unlocking and is it "normal" or do I need to get it checked out? I'm on asphalt at the moment. Hope that makes sense
Reactions: TxDoc
lukpy8810
lukpy8810
91
203
Minnesota
The cables in the box under the rear floorboard need to be adjusted most likely.
Makes sense I've been in there but probably need to do some more fine tuning. Is it normal it to be kinda lurchy at low speeds in turf more?
Reactions: TxDoc
WagginTail
WagginTail
1,656
6,075
SC
Not normal for mine. Here's a link to video you can watch. The adjustment can be very finicky.
ODAMO
ODAMO
1,400
3,675
Don't confuse low speed throttle lurtchiness with locker adjustment. All the P1000s have ill designed throttle geometry that causes the vehicle to lurch in certain conditions. However the pop/clunk from the rear diff is caused by a misadjusted rear locker cable. Once adjusted properly no more clunk
Reactions: TxDoc
DRZRon1
DRZRon1
1,456
4,444
it can be lurch ee in all modes - is turf mode more lurch ee than others
Reactions: TxDoc
Scoop
Scoop
5,438
21,385
  3. Talon R LV
My P1K5 has been sticking in 2WD lock lately. Gonna do the diff adjustment today. That video is thorough!
Reactions: WagginTail
