P500 New P520 leans to the passenger side
crewcabrob
crewcabrob
1,029
4,039
Omaha
Hi all,
I did a quick search in the P500 forums to see if I could find a thread about Pioneer 500/520s leaning to one side or another. I could only find a thread in the P1000 forums, but a P500 owner has the same issue.
My P520 leans to the passenger side. I can only assume it is because of the weight of the fuel. I keep a full tank and fill it up after each ride.
Does anyone else have this? Am I missing something that I should be looking for as a reason it leans? The reason I ask is: the dealer I purchased the Pioneer from was rushed to get it put together for me and missed a few nuts and bolts here and there. A couple of the ROPS bolts were missing as well as a couple of skid plate fasteners. The Pioneer made a terrible racket as the skid plate banged around and the ROPS did the same. Its much quieter now that I have everything bolted together... or do I?
Thanks,
Rob
crewcabrob
crewcabrob
1,029
4,039
Omaha
Thanks guys!
I will grab some pictures this afternoon and post up.
I suppose it could be an optical illusion on my part, I tend to be more detail oriented after a few drinks...
Rob
273,601
Thanks guys!
Rob
Did you check tire pressure? Difference can cause it to appear to lean.
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
As said, check equal tire pressure and shock adjustments notches. Inspect shocks as a member had them installed upside down. Use a level to confirm, on the ground then on the sxs, eyes can fool you.
crewcabrob
crewcabrob
1,029
4,039
Omaha
5C5ACFBD 22B4 48DE A8E1 2E3D8B9687ED
5CA80441 5F6E 400F B8B5 4E23AC1DE30C
0D684154 A1B0 46D0 B06F BB0F89F0D3EA
BDE6B804 7902 42E6 BFA8 A63F7CBA8806
Thanks guys. Yep, checked the tire pressure first, all tires are at 6 psi.
On level ground and confirmed with a level, the driver side is more than a 1/4” higher. I measured at the frame right in front of the rear tire.
crewcabrob
crewcabrob
1,029
4,039
Omaha
Nope, we aren’t big people. Neither of us weigh more than 170.
I agree that the fuel can’t weigh much either. Everything looks right on the suspension and the shock adjusters are both set to the same notch
JenElio
JenElio
75,160
677,597
Loxahatchee, florida
Not too familiar with the P500 but my P1K5 will change a bit by rocking it from the top side to side. I mean..........personally 1/4" wouldn't bother me 🤷‍♂️
(no homo)
