Z
Lots of choices and theories out there. I’m not made of money so I enjoy forums like these so that you can hopefully make the correct choice for your particular situation.
Tire diameter? Tell me again how much cooler your feet are with the roof off? 🤔I am running the System 3 SB-4 7x15 with 6+1 in the front and 4+3 in the back so no need for spacers. Be careful if you use a 14 inch wheel because it does not leave enough clearance between the wheel and the brake and hub components and rocks and other debris WILL get stuck in there and you could cause damage. I have seen it happen. BTW nice looking ride and good luck with the new Machine.View attachment 226707
Yep, it's the go-to solution.Nice wheels idiot. I suppose I will go with 15" wheels. Probably same as your set-up (different rubber). So If I had to run a front on the back temporary as a spare with your set-up that would work?
I’m running the tusk wasatch beadlock 15x7 5+2 offset with no spacers. I have a matching 5th wheel/tire for spare. Not in photo, need to get mount for spare yet.
Hey guys,
I am in the same situation as the original post... long time p500 and p700-4 owner. Just bought a 2021 talon x-4 non Lv. Love the machine so far besides the low speed rough ride on rocks! Really curious to how bad the rubbing is with 32 inch terrabites on stock wheels or tusk headlocks. Can’t decide between 30s and 32s. Anyone have a pic of the clearance in the fender well at full turn? Have bandit tenders on the way too, hope to have and install them this afternoon.
Hotrod- these are 32s, right?
Thanks in advance.
If you don't mind me asking, what does it measure across the outside in the front now?I have a 2019 Talon 1000X. I just got my 32” Terrabites mounted last weekend and we are going riding tomorrow and Saturday. I can let you know how it does next week. I also installed the Bandit tender springs. Will be trying them out for the first time weekend.
Rednick-I have a 2019 Talon 1000X. I just got my 32” Terrabites mounted last weekend and we are going riding tomorrow and Saturday. I can let you know how it does next week. I also installed the Bandit tender springs. Will be trying them out for the first time weekend.
