new x4 have questions :-)
Z
Zona
23
45
Arizona
33 miles now :)
E097A7AD 9A62 402C A378 5F19BC6E2935
IDIOT
IDIOT
279
751
Kingman, Az.
I am running the System 3 SB-4 7x15 with 6+1 in the front and 4+3 in the back so no need for spacers. Be careful if you use a 14 inch wheel because it does not leave enough clearance between the wheel and the brake and hub components and rocks and other debris WILL get stuck in there and you could cause damage. I have seen it happen. BTW nice looking ride and good luck with the new Machine.
IMG 6011
11,303
83,913
Welcome to the forum. Nice Talon.
5,018
22,391
I am running the System 3 SB-4 7x15 with 6+1 in the front and 4+3 in the back so no need for spacers. Be careful if you use a 14 inch wheel because it does not leave enough clearance between the wheel and the brake and hub components and rocks and other debris WILL get stuck in there and you could cause damage. I have seen it happen. BTW nice looking ride and good luck with the new Machine.View attachment 226707
Tire diameter? Tell me again how much cooler your feet are with the roof off? 🤔
Reactions: Mudder
Z
Zona
23
45
Arizona
Nice wheels idiot. I suppose I will go with 15" wheels. Probably same as your set-up (different rubber). So If I had to run a front on the back temporary as a spare with your set-up that would work?
Reactions: Mudder
5,018
22,391
Yep, it's the go-to solution.
Reactions: Mudder
Vondy
Vondy
1,387
8,826
Houston,OH
14” has more tire and rim choices but 15” is quickly becoming popular as well with plenty of choices.
I stayed with 15” since I heard of some 14” rims rubbing caliper or stones getting stuck between.
I run 5+2 all around with 1.5” spacers on rear. I think the spacers were from dune gear on eBay. USA made I believe.
I had a X2 first and now a X4. I run 32” carnivores on 5+2 SB4. Around 600-700 miles of mostly TN riding on this Setup with no issues.
You can check out my build thread. Starts with X2 then switches to X4 but I moved all accessories/upgrades over to theX4.
CDA45E87 5FD8 482E 9A58 046848353B07
34F65982 826E 48DA 867C 7D732F259738
02C8D5DC 1722 4DC5 B19C CFBED000B12C
Z
Zona
23
45
Arizona
Nice ride Vondy! I’ve decided to go 15” on wheels from everyone’s feedback. Leaning towards a 30” tire. I don’t want to bog her down to much with a lot of tire.
Reactions: Blownzuki and Vondy
Z
Zona
23
45
Arizona
well money seems to be tight to get wheels right now. I've came to this solution. 30x10 kanati mongrel on stock wheels. Where do most of y'all get the tire deals from?
hotrod8605
hotrod8605
I’m running the tusk wasatch beadlock 15x7 5+2 offset with no spacers. I have a matching 5th wheel/tire for spare. Not in photo, need to get mount for spare yet.
BeachBum
15
12
DFW Texas
Hey guys,
I am in the same situation as the original post... long time p500 and p700-4 owner. Just bought a 2021 talon x-4 non Lv. Love the machine so far besides the low speed rough ride on rocks! Really curious to how bad the rubbing is with 32 inch terrabites on stock wheels or tusk headlocks. Can’t decide between 30s and 32s. Anyone have a pic of the clearance in the fender well at full turn? Have bandit tenders on the way too, hope to have and install them this afternoon.
Hotrod- these are 32s, right?
Thanks in advance.
Rednick69
Rednick69
154
1,260
White Hall, AR.
Hey guys,
Thanks in advance.
I have a 2019 Talon 1000X. I just got my 32” Terrabites mounted last weekend and we are going riding tomorrow and Saturday. I can let you know how it does next week. I also installed the Bandit tender springs. Will be trying them out for the first time weekend.
A0e91bb72436dd16303da86dba465f26
F7521e6a0859115c1bf461a9bcf66536
6df913e8b359564c7ac9ed023be7c015
P
PT1911
11
SE MN
BeachBum
15
12
DFW Texas
Rednick-
Great looking rig! Yes I’d love to hear how your experience is with your new 32’s. I just went to install my new bandit tenders and they sent me the wrong set. The fronts are way too wide or fat for the front shocks... of course can’t get ahold of anyone either. Hope they get back to me via email soon. Surely they will make it right.
look forward to hearing how those tires ride. Thanks
