P1000 Newb Need Help on Tires
jelmail2000
jelmail2000
30
41
US
I know what you are thinking - not another tire post, but i could use your help. I had a polaris with these big lug V shaped tires and i did not like the tires at all. I was happy to get rid of that thing and get back to honda. I was also excited to see the tires it came with because i always read good things about them. Well, i was just riding with the family and i destroyed one. I have no idea how. I mostly ride dirt trails but there are some rocky parts here and there so the only thing i could think is maybe i hit the side wall. I am not upset it happened but it does give me the opportunity to think of what to put on the machine now.
So now it is time for new tires. I ride dirt, and rocky mountain trails. I do love to puddle stomp but it I do not find many here in CO and it is real tough to find mud. When i went to taylor park almost every machine had car looking tires on them. I can see the benefit of having 4 of the same in the event of a flat. Is having 4 of the same size tire all around a good idea? What would be a strong sidewalled durable tire that can handle trail and rocks? Lastly, would i need to change out my rims? I have the deluxe rims if that matters and currently my rear tires are wider than the front.
I appreciate any help and thank you in advance!
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I like STI black diamond XTR .
jelmail2000
jelmail2000
30
41
US
do you buy 4 of the same tire or do you buy the wider back tires?
Reactions: Plumber32
Amre2me2
Amre2me2
381
1,423
Colorado
A lot of guys are running the Terrabites. Probably the best all around tire if you need a DOT tire and run on some asphalt. I only run on horrible rocky trails or snow. So I went with the 8 ply Sedona Ripsaws. 28x10x14 all the way around on stock rims. The fronts are tough to get to seat on the 9" rims but I was able to get it done.
What tires you run will be dictated by what your running them on. A good tire for one guy might be a horrible tire for the next guy.
ohiohunter
ohiohunter
103
141
Minerva Ohio
I just put the maxxis coronado on today and road them around about 10 miles and i'm really liking them so far. There much more stable and quite then the big horns. 28x10x14 all the way around.
jelmail2000
jelmail2000
30
41
US
I will not run on asphalt often. I live in Colorado so i mostly run rocky trails or worse. I am looking for something that can hold up to that abuse if possible. I like to puddle stomp but there aren't many here.
Are you all using the same stock rims and having the larger tire on the back?
Reactions: gpd2111
105,566
I just ordered 215/75/15 BFG mud terrain km2 and 15" Rockstar series 1 wheels. Should be good for nearly everything and last forever.
Make sure to show us some pics when you get them. Interested in seeing how they look
Reactions: moparornocar
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I run the Sedona RipSaw R/T tires as @Amre2me2 showed you above...I agree that it depends on the terrain you ride on...The RipSaw's are great for the rough, but I think the pavement would tear them up ....
