I didn’t even think about asking them about PSI lol I’ve been on the phone with them on and off about ride height and adjustment on the shocks, I’ll call them back
Ride height is easy, a stock 2 X is spec'd at 12.7" ground clearance, allow for aftermarket tire size, if any, and turn the preload rings until you get where you want. I want the engineered geometry so I added an inch to allow for my 30" tires - easy peasy.
Did you get cross over rings with the ST work? If so, there's a lot of options there too but I'm not very well versed on those intricacies. On my R with stock springs, I backed the cross overs way off so I'd spend more time on the softer springs before crossing over but that was completely unscientific, a softer ride was more important than perfect cross over function.
Obtw: if you aren't backin' 'er into the turns, try unhooking your sway bar to improve the ride even more. For the R guys, you have to undo both SB links and tie the SB up or it'll hit the upper trailing arm.
In case you haven't seen it, check out the New Talon Owners thread for some useful Talon information -
I'm new to the SxS world - damn, there's a lot to learn, hence this thread - maybe we can make it easier for others new to the Talon and put it in one thread. 1. If you're a motorcyclist, you already know that sometimes your bike won't shift into gear at a stop without rocking the bike back and...
hondasxs.com
