P700 NO POWER DURING ACCELERATION
Davidgaud
15
11
La Tuque
No power during acceleration
I bought a new Pioneer SXS700-4 in 2014 and I have a first major problem in 4 years.
I have no more power when I push the accelerator. If I go downhill, the transmissions will be able to change gears by releasing the accelerator but if I'm on a board or uphill, I have no power. The engine does not stop, it starts very well and runs very well to the idle.
I checked my air filter, my spark arrestor, replaced the sparkplug and the problem is still there.
My pioneer is at the Honda dealer in Quebec, Canada for 3 weeks and they have not yet found the trouble. the mechanic adjusted the valves. I asked to check the muffler following exchanges on your forum as there had been power loss issues but everything is OK with my muffler.
There, he is waiting for the delivery of a special tool to be able to remove the gas pump from the tank and check the gas filter. The tool does not appear to be available in Canada and will take 2 weeks for delivery.
I'm afraid the trouble is not at the gas pump or the gas filter.
Do you have any ideas because I do not have any more,
(Excuse my english, I speak french and use Google traductor to write you my problem)
Reactions: Plumber32
William
William
1,442
2,887
Flowood MS
Sounds like the cam shaft. A friend of mine had his cam replaced due to the same problem. The lobes on the cam wore off...
Neohio
Neohio
Beast of the East
17,909
86,473
Painesville Ohio
Bad camshaft should be easily diagnosed with a compression test.
If he checked and adjusted the valves, I would hope he would have found the bad cam then and there?
Reactions: joeymt33
Davidgaud
15
11
La Tuque
If I had a cam shaft problem, would I hear an abnormal sound to the engine? currently I have no abnormal noise, the engine runs very well!
Davidgaud
15
11
La Tuque
The mechanic did not do a compression test just a valve adjustment. It seems to me that he would have had a sign at that time if I had a cam shaft problem, No ?
43,292
Cam.
Fuel pressure gauge (and maybe capacity ) test tells the tech everything they need to know about the fuel pump.
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
Just thinking outloud...
An air restriction would give you these symptoms.
Enough air to idle fine but not enough air to provide power.
You checked the exhaust and the filter. Look for anything else blocking the intake of exhaust.
Does it studder when you press the accelerator? or only lug down?
Reactions: Farmer and swsebek
Davidgaud
15
11
La Tuque
Cam.
Is the mechanic forced to pull the pump out of the tank to do a gas pressure test?
What do you mean by Capacity test ?
Reactions: DG Rider
Davidgaud
15
11
La Tuque
Davidgaud
15
11
La Tuque
For info, the mecanic remove the muffler and ride the pioneer to check there is no restriction and the problem is still again.
I'm not sure I understand your question; When I press on the accelerator, there is no abnormal noise. We just feel the loss of power. The pioneer go slower but the engine does not stop.
43,292
No. A fuel pressure gauge can be installed by disconnecting the fuel line ( it installs like a tee in the fuel line). A capacity or volume test is done by simply disconnecting the line and placing it into a container to measure the amount of fuel being pumped over a set period of time.
The latter isn't done much these days, as an experienced tech can usually tell by the speed with which the gauge rises as to how healthy the pump is.
The point being that there is no reason to "check the filter" if the pressure and volume are good.
Reactions: swsebek
Davidgaud
15
11
La Tuque
Thank you for the info. I will call this morning at my dealer honda
Gator
Gator
2,488
10,464
Louisiana
I wonder if it is stuck in high gear.
Davidgaud
15
11
La Tuque
My mechanic is supposed to receive on Wednesday the "T" to do the pressure test of the gas pump.
It's amazing how long it takes to get these Honda parts. It's been almost 2 weeks since the order was placed.
Davidgaud
15
11
La Tuque
No, the 3 speeds change well. It starts well in first gear except that it is long to go in second and third with the lack of power.
A
arl242
14
23
Tipton, MO
My 2016 Pioneer 700 has been acting sluggish for month or better. It has roughly 1,000 miles on it. No get up and loses speed going up hills. Last week I stopped by the shop to see if there was anything I could do before having to spend a lot of money on it. I was advised to change oil, air filter and spark plugs. I did 4 days ago, nothing changed. I took it to the shop yesterday. The shop called today stating it was 1 1/2 quarts low on oil (don't know how since I just changed it) and that my warranty would not hold since it was low on oil when they received it. They think it is a cam and are blaming it being low on oil. I run a small farm, I know the importance of oil. Honda is not standing behind their warranty. The shop is not helpful either. They will know more once they get inside it. Their estimated guess for cost of repair was $600-$1,000.
Davidgaud
15
11
La Tuque
I have many qustions:
1- Is your repair completed?
2- Did they replace the camshaft?
3- Did they respect the guarantee?
4- How much did your repair cost?
Davidgaud
15
11
La Tuque
I d'ont know what to say anymore !!!
By 2 times they have not received the right "T" to take the pressure, incredible!
They managed to turn off the gas pump and checked the gas filter that was dirty. They removed it and tried the Pioneer again and the trouble was still there.
Then they spoke again with the honda tehnique support and the guy said it was probably the cam.He should get the cam on thursday.
I am discouraged,
Neohio
Neohio
Beast of the East
17,909
86,473
Painesville Ohio
@Davidgaud not knowing your mechanical abilities, but I would highly suggest you purchase a service manual for your machine. Www.helminc.com prints them for Honda.
With the manual, and decent mechanical skills, you should be able to replace the cam yourself. Not a lot of tools are needed either, the only specialty tools that are not in a household toolbox are feeler gauges. They are easily acquired at CTC, Princess Auto etc.
Reactions: popeye and Mudwing
43,292
I am discouraged,
Just glancing at the fittings, it looked like garden-variety QD auto stuff available at any tool source, but maybe that's not the case.
I also don't like "probably the cam". Would your shop really tear down an engine based on "probably"? Someone needs to do a compression test or simply watch the valves while cranking the engine before they start throwing parts at it.
