P500 No power or lights despite full battery
ChasinFin
7
California
Hi there,
Recently bought a used 500 (2018) and it worked great all hunting season. It's been sitting for a few weeks and went to move it with out any juice. i thought my kids must have left the lights on or something and drained the battery however i went to charge it and its 100% full. So i thought perhaps a fuse busted but i checked under the passenger rear fender and all fuses were fine. What am i missing here.
When i had the battery charger hooked up and turned the key it would flash on the dash and make some clicking sound.
Any help would be appreciated!
Reactions: rtn001 and Isaiah
Mudder
Mudder
NTC Ambassador of Walls
11,304
83,933
Sounds like a dead cell battery, maybe from full discharge.. Mine would show full on charger, but failed on load test. Also, if its an AGM battery, a non-smart charger can do damage.
ChasinFin
7
California
That seems like the only solution but just wanted to make sure i wasn't missing anything silly. probably not a bad idea to get a new battery anyway. i'll run a search on here and see what folks recommend.
Reactions: rtn001 and Mudder
Mudder
Mudder
11,304
83,933
I went with OEM AGM Yuasa GYZ one. Was at dealer when they tested the old one.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
2,875
19,368
Route 66 Oklahoma
Agree on the Yuasa. I have a P500 and 3 Honda 4 wheelers, and have not have one fail. I replace them every 4 years just for peace of mind. 👍
70Bones
70Bones
888
3,779
New Brunswick Canada
Before you give up on that battery, clean the connections and also take the ground off the frame (to the right of the battery box) and clean it up good before re-assembly. These are common issues that can cause that sympton.
