P700 Not enough power to turn the wheels
brettm1
7
iowa
I also just bought the 700-4 2017 and am not happy at all it is very very sluggish does not seem to have the power to spin the wheels with 2 small kids and my wife and I in it also the trails speed limit are 30 to 35 it has a hard time keeping 30 on blacktop roads I realize it's not a car nor built for speed but for being brand new under 300 miles I'm not very happy
208,013
First, Welcome! The 700's are little low on power, some friends of mine have a 16. But they are very capable trail machines and more maneuverable than a P1 in tight woods, I know.
Something is off if it can't keep 30 on blacktop.
Steep Hills? Big tires? If neither of those it might need to go back to dealer.
Reactions: Deluxe700
brettm1
7
iowa
It is all stock I have taken it back they say it's fine I'm really considering trading it in on something else
208,013
I really like my P1, If you don't get the LE you will need to up grade shocks and get skids.
xltman
xltman
188
369
US
I have a '16 700-4 and have no problem holding 40 mph with three other adults in it. Something ain't right.
Theron
Theron
50
30
Anchorage Alaska
P1 Review...
So for background I have a P700-4, started this post due to lack of power in a few scenarios (see signature for setup). Borrowed a buddies P1000-5 Deluxe, Front hard cab and doors (heavy) and soft around back, lift kit (not sure height), heater, 30" Silverbacks! Loaded up with weekends worth of hunting gear and 75lbs son. Put 140 miles of steep hills and deep mud through some of the nastiest terrain Alaska has to offer. First thing that surprised me was the tires would not spin on this one trip more times than has ever happened with my 700. I know its not meant for 30" Silverbacks, that being said I could go through anything and the times the tires bound up (yes even in low and not in diff lock and in reverse) I could always get it to go and get out with a little back and forth. That thing is a beast. Not a fan of the heavy cab, yes it kept me warm and dry in some very inclement weather, but the added weight and constant fogging when driving through water (constantly) is not worth it to me. In the end I am considering getting the P1000 someday. Would need shock upgrade as my 700 with fox is much better. For those wondering the Silverbacks were beasts but did rub on several occasions (Full hard turn slow, and hard bumps in front) so I would go with just a bit smaller size with the lift setup he had. On the other hand my 700 set up the way mine is, is a pretty impressive machine and am very happy with it for the most part, especially when you consider the cost difference....Whhooo... I'm out of breath after that.
Reactions: joeymt33 and Gator
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
P1 Review...
Thanks for the review. I think moving up to the 1000 is something every 700 owner ponders at some point. It's good to have this unique perspective.
