Talon OEM Shock Adjustment
GoTalon
GoTalon
Yuma, Arizona
Just wondering if anyone out there has played around with their Crossover rings or anything else to change the Ride in their Talon R and if anything helped. As most people know the Talon R (not sure about the X) ride extremely harsh on slower speed chatter and bumps and with out spending a bunch more money on different Tender Springs or even a whole ew set of Springs, can anything be done?
PaulF
PaulF
1,462
4,815
I backed my rears off just shy of the tender springs binding (I think it was about 25 turns if I remember correctly). Softened it up quite a bit. I also did the fronts but not quite as much (don't remember the number of turns).
Just be aware that it will bottom out a little easier if you do it because the stiffer bottom springs kick in at a lower suspension level so do 10 turns at a time until you get what you want without coil binding.
DAJO
182
125
Indiana, Arizona
Raising the crossovers helps a lot. Doing Shock therapy springs and revalving amazing.
