T
Just went over 109 miles and figured I’d go ahead and change oil and filter. I just bought a gram filter (6015) at Walmart and it says it fits pioneer too. Would you use this filter? What type oil? Thanks
I will change the o rings every few changes, but keep them on hand in case there is an issue. Seems like new ones are more prone to getting nicked. Make sure you lube them with oil.Do you always use new o rings during oil change? Do you torque the bolts? I never have on ATVs but probably should have. But I never had trouble. Where is the beat place to get torque wrench? Thanks
Out of curiosity, what synthetic do you use in your SxS?IMO, first oil change, I'd recommend all Honda oem. Second oil change, Honda filter and full synthetic.
TFAR and TooFar are not all that far apart for some so definitely avoid apprentice-tight. If it leaks you can always give it another eek of a turn. If you go TooFar things are a pita and often costly in a hurry.Thanks for the replies. I change oil in our vehicles and motorcycles and have always just used the TFAR method ands haven’t had any problems. Glad I learned that method had a name. Lol
