Oil leak
smokinit
69
So I noticed the other day I have an oil leak coming from around the shaft going into the transmission on the rear. Two questions.
Is this common occurrence?
And is it a major project to replace the seal? Or does the shaft just slip out replace the seal and slip back in.
Thanks in advance.
Sent from my KYOCERA-E6560 using Tapatalk
swsebek
swsebek
2,854
5,835
pa
Pics please
smokinit
69
KIMG0292
Here is where the oil is coming from.
smokinit
69
KIMG0293
And that's the oil spot... Not a bad leak. But I wouldn't expect to have a leak like that at 3k miles.
Road Warrior
Road Warrior
72
163
Palestine, IL
I haven't had that problem on my pioneer but I did pull the shaft on my Rincon (same setup basically) to replace the final drive gears and it wasn't a major deal.
I just looked at my 700 - remove the brake caliper, remove the 5 bolts securing the driveshaft flange to the rear yoke and the shaft will slide out of the transmission. Drain the oil prior to doing this or you will make a mess.
Reactions: Tflynn and swsebek
smokinit
69
That's what I figured. Just wanted to know what I was up against before I start in.. I am in need of a service any ways so no better time than now to do it
A
AWolf
Houston, TX
Hey Smokinit,
Did you ever fix this leak. I have have the same issue. Do you remember what the Honda part numbers were? I know it was over a year ago. TIA
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,271
22,397
Route 66 Oklahoma
Hey Smokinit,
Hey @AWolf . If you want to get smokinits's attention, write it like this: @smokinit
A
AWolf
Houston, TX
Thanks @SILVER_ALERT!
Hey @smokinit,
Did you ever fix this leak. I have have the same issue. Any Advice or steps you could share? Do you remember what the Honda part numbers were? I know it was over a year ago. TIA
43,589
I did that seal at around 7800 miles if I recall. Seal is like $3 (I have an extra one lying around somewhere), but you have to loosen the rear diff and slide it back to get the driveshaft out to do the fix. You also lose some oil, so maybe do this right before an oil change.
