P1000 Oil level
Bparker
Columbus,ms
Just changed oil is it a big deal if oil line with dip stick not screwed in is just barely above the full line??
Reactions: TxDoc and Isaiah
Gabbas
Gabbas
280
701
Humboldt, Iowa
When checking oil, you do not want to screw in the dip stick. It should be fine where it's at.
Sent from my Pixel 4 using Tapatalk
Reactions: Bparker
F
Fischer
209
321
The woods
I did the same thing. Its almost impossible to put the exact same amount in every time. So I hope Honda gives us so grace on that when they design the engines.
Reactions: Bparker
5,429
24,931
I wish Honda had put a sight glass in the Talon like my motorcycle, a much easier/quicker way the check the oil level.
Reactions: wrhii and Bparker
