Talon? Probably similar to the P1K?The P1K is over 100psi
The P700 is close to 100psi
Not sure about the P500
I have no clue. The parts book says it is an 8 mm so you will need to pull and measure.Paul, do you know if those straight threads are 6mm x 1.0?
