I had a stroke and don't have use of my left arm at all. Am I going to be able to operate the reverse at all.?my 520 I on order and due in soon.
Welcome from south FL....I had a stroke and don't have use of my left arm at all. Am I going to be able to operate the reverse at all.?my 520 I on order and due in soon.
If the P520 is like the P500, simply tighten up the reverse lever cable adjustment (from inside the hood) which will act as the lever being constantly pulled. Here’s a link to a thread with video. Hope this helps and best wishes on the recovery.I had a stroke and don't have use of my left arm at all. Am I going to be able to operate the reverse at all.?my 520 I on order and due in soon.
Welcome from NE Ga…Let the good times roll!I had a stroke and don't have use of my left arm at all. Am I going to be able to operate the reverse at all.?my 520 I on order and due in soon.
Howdy from Oklahoma and welcome to the club. I had a couple of strokes within about 3 months, a few years back. Fortunately I did not have any physical problems. It just left me a little befuddled in the head. My wife and friends told me that they could not tell any difference. I don't know if they are just being nice, or if I have always been goofy. Hope you get well soon. 👍I had a stroke and don't have use of my left arm at all. Am I going to be able to operate the reverse at all.?my 520 I on order and due in soon.
The reverse lever bypass mod was so easy even I could do it.
Mine was done the day I got it home, years back. I'm sure others have been done even longer.On the fence about this mod. Are there any drawbacks from a mechanical standpoint in having the lever and associated trans components in this "stressed under tension condition". Asking for a friend.
What Trigger said.It doesn't put any stress on the trans at all. I did this mod right away as well due to plowing with mine and that lever was just a pita. It's just a BS safety feature that they put on to make you conscious of the fact you'll be backing up. There's a similar feature on my JD lawn tractor. It won't even go into reverse until you're nearly at a dead stop.
From a mechanical engineering standpoint, the stress under constant tension is most likely much less than cyclical strain and relief from repeatedly operating the lock out lever.On the fence about this mod. Are there any drawbacks from a mechanical standpoint in having the lever and associated trans components in this "stressed under tension condition". Asking for a friend.
