P500 One handed reverse
JenElio
JenElio
63,932
600,455
Loxahatchee, florida
I had a stroke and don't have use of my left arm at all. Am I going to be able to operate the reverse at all.?my 520 I on order and due in soon.
Welcome from south FL....
I'm not too familiar with the P5s but I believe there is a over ride/bypass for that. Someone more knowledgeable then me will sure comment.... @trigger @Mudder
11,301
83,894
If the P520 is like the P500, simply tighten up the reverse lever cable adjustment (from inside the hood) which will act as the lever being constantly pulled. Here’s a link to a thread with video. Hope this helps and best wishes on the recovery.
OlYeller15
OlYeller15
192
1,170
r
Welcome from NE Ga…Let the good times roll!
The Green Goat
The Green Goat
1,737
12,296
Reverse lever bypass as Mudder mentioned. Best free mod out there. While cruising around, I frequently have a beverage occupying the use of my left hand, or I'm just being lazy, so I shift/drive/change music selection with just my right hand.
You'll be fine.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
2,874
19,363
Route 66 Oklahoma
Howdy from Oklahoma and welcome to the club. I had a couple of strokes within about 3 months, a few years back. Fortunately I did not have any physical problems. It just left me a little befuddled in the head. My wife and friends told me that they could not tell any difference. I don't know if they are just being nice, or if I have always been goofy. Hope you get well soon. 👍
P
pappyo
593
2,377
1st. Welcome from central upstate N.Y
Many good people & imformation on the Honda forum. & they like PICTURES
Red was the 1st color all other colors followed Honda hopes they sell.
P520 <>Reverse Lever adjusted Out <> Spinner Steering Knob <> EPS <> Should make Excelent Set-up for situation.
Good Health <> Good times <> in the future.
104,944
$hit man! You buy the dunes!
Welcome fellow michigander!
Like you said, post some pics when u can! #POIDH
Y
Yomama101
139
1,021
Mesa AZ
  1. Looking to buy
  2. 520
On the fence about this mod. Are there any drawbacks from a mechanical standpoint in having the lever and associated trans components in this "stressed under tension condition". Asking for a friend. ;)
Reactions: Buggyman
hallic
hallic
320
1,795
Central MN
Mine was done the day I got it home, years back. I'm sure others have been done even longer.
It's probably actually less stressfull on the system, VS constantly yanking on the reverse handle and stressing the cable. Ya ever hang out with a buncha guys on 3wheelers, and have to do 8 point turns for hours on end cuz you cant follow em on their dinky little trails? lol, woulda yanked out my hair if I had to keep jerking on that reverse lever...
155,526
It doesn't put any stress on the trans at all. I did this mod right away as well due to plowing with mine and that lever was just a pita. It's just a BS safety feature that they put on to make you conscious of the fact you'll be backing up. There's a similar feature on my JD lawn tractor. It won't even go into reverse until you're nearly at a dead stop.
Reactions: Mudder and Buggyman
Splorin
299
838
Maine
Gubmint and lawyers threw that lever in there because you can't be trusted. Adjusted so long ago that I forgot it was there till you posted. Get well and take care of yourself. Been there, done that. Pound your P-5 for medicinal purposes...........
11,301
83,894
What Trigger said.
driller
32
146
WV
From a mechanical engineering standpoint, the stress under constant tension is most likely much less than cyclical strain and relief from repeatedly operating the lock out lever. ;)
