Outkast A-Arm review
Samboc19
Iva SC
Anyone running the outcast A-arms on the p500 having problems with them? I’ve heard good and bad.
I really would rather not have to move the tabs forward but if I do who can sell me a bracket kit?
Reactions: TxDoc
156,537
I've had them on mine for a couple years now, no problems. The only issue I had was at install, raising the front end causes negative camber on the front wheels, tops tipped out. Reducing the preload on the shocks lowered it back down enough to take it out. It was mainly on the passenger side. That's also with 28's, if you're going with big o' tractor tires it might be worse. What's the supposed issue or concern?
Samboc19
Iva SC
I’m fitting 29.5s on no lift right now but I’m planning on portals, a arms and 35s
Bastardchild
Bastardchild
1,978
7,250
Orange Heights, fl
Check out Ridin Dirty forward a-arms for the P5. I know a handful of guys up in Georgia that run them and they are some good looking well built arms. Back when I had my P5 I put 6" portals and 35" Superior Traction tires on mine and I had to move my tabs forward because nobody made forward a-arms at the time. I dont know their website or facebook though. I dont do gaybook. Good luck.
I got the frame mod and only spot it touches is a little on the inner fender
156,537
Ridin Dirty quit making them for the P5. That's what I wanted but had to go with OutKast. Even then I wanted that brace that RD makes that ties the A arm brackets together, they're not available either.
TexasLineman
TexasLineman
Conroe
What did you use for bushings?
TexasLineman
TexasLineman
Conroe
They were provided by OutKast. Were supposed to be pressed in I thought, they weren't.
Wasn’t sure about that, I was trying to get out in front of the a-arms arriving without bushings
