Over heating
Hollerboy36
West Virginia
My 700 4 is over heating and the fan is not coming on. What do I need to do? I’ve clean all the mud out of the Radiator and tries to check for air bubbles in it too.
43,070
Check the fuses. There is one for the fan.
If it proves to be good, check for power to the fan. The issue there is to make sure the computer has turned the fan on. You can run the machine until it's getting hot (3 bars on the gauge should do it)...just be careful not to let it get too hot.
Or...probably the easiest was is to simply unplug the coolant temp sensor. With it unplugged, the fan will run as long as the key is on.
Ideally, you like to check the voltage with the fan plugged in, but if you don't have the proper probing tool, just checking at the connection with a test light or volt meter will do.
Reactions: Montecresto
