P500 p 500 rear end noise/whine
Why is my 2015 p500 making this noise. Mostly in 4th and 5th gear.
Are you in fourth and fifth gear at those speeds???!!!! I have a 15’ and it doesn’t sound like that.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
I have a new 2018 with 40 miles on it, and it makes the same sound, in 3rd, 4th, and 5th. Waiting till 100 miles to change to thicker synthetic gear lube like everybody recommends. I am hoping it goes away, just because my brain tells me it shouldn't make that sound. :)
tlynn
14
22
wimauma fl
(CAPS ARE STUCK ON) I DOWNSHIFT WHEN I NEED TO MOST OF THAT CLIP WAS IN THIRD WITH NO LOAD AND ALMOST LEVEL GROUND FOURTH AND FIFTH ARE MUCH WORSE WILL CHANGE FLUID SOON>
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Sounds normal to me. You can search here and elsewhere, but many have added a "pad and/or heat shield" under the seat and it will noticeably reduce the noise....
Reactions: SouthwestORV
Yo DG, have you every ridden to the "Coke Ovens"?
These?
9680C418 8BE0 45AC A589 F593B24EEF0A
Reactions: lee
I want to ride my P500 to both of those. :) Let’s talk next year when weather warms back. Have you been to either of these?
I’ve been to the coke ovens outside Trinidad. By all means, let’s see what we can do when warm weather returns!!!
lee
lee
Village Idiot
2,350
13,231
Springfield Ohio
looking at the Florence coke ovens I had to wonder, how much wood dose it take to fill it. Look around where the hell did enough wood for 5 ovens come from?
Sorry, engineer in me comes out sometimes.
Reactions: Montecresto
I think that coke is a biproduct of coal. There’s no doubt coal mines/shafts nearby.
