P500 p 500 softdoors
dls1966
dls1966
192
569
Kawkawlin Michigan
The fit of the doors is off ,they only go halfway down on the stock doors so there's a bit of a Gap, but I've had mine for a couple of years and they work well,keep the cold out and I would recommend them they make a big difference
Todd627
Todd627
56,736
619,454
MI
I agree with @dls1966....
05D47D61 5ACB 43BE 97FE 7B1D96A2D983 0ED7EE2D EC97 4E93 AA35 8B43EE3B9FC9 33BFC0E1 94DE 4932 8BB1 63314C50D4F9 9C0A97E8 3750 4085 9A4C E8518262EB10
V
vinnie55
dubuque ia
Thax Dls that helps me alot !! im ordering my doors tmr ! it will be fun to make them even better with tips from this site !!!!!
Jnwit
Jnwit
7
Mediapolis, IA
Do not trailer with doors on unless no wind and doors secured with straps. Better yet cover on the whole rig. Best - dont trailer with doors on. Pulling out of dealer mine got ruined immediately. Tags on doors warn of such. Duh me... and dealer staff, it was brand new and I didn't know. I use doors 9 months of the year in iowa and open windshield to control dust. Wife likes the doors on.
V
vinnie55
dubuque ia
hi i like the the pics !! im in northeaest iowa . its getting cold !!
A
Avi8or
40
81
Mo
I have the Honda doors. I like them. They don’t seal up perfect but they block most of the cold air.
They are finicky to install. Just take your time with the alignment.
NitroxDiver
NitroxDiver
488
918
Concord NC
Just put them on my machine. They don’t seal well but with that said I get more air cold from the reverse lever and 4wd lever than around the doors. I plan to block off the airflow around these levers. Definitely help in cold weather.
Reactions: dls1966
182,443
I started messing with that idea, making a pattern for the shift lever is a pita. Wonder if the knob comes off?
Reactions: Normanator22
NitroxDiver
NitroxDiver
488
918
Concord NC
I am thinking about pulling the hood off and trying to make a rubber or plastic panel that seals off the back of the dash in front of the switches levers and steering shaft. I find in the summer I get a lot of hot air through these same holes.
nctrailboss
nctrailboss
440
1,454
north carolina
I got the Over Armour doors on.Easy install but I did not care for the stick- on velcro strips so I melted small hole around those areas and zip-tied to the roll bar.They will un-zip and roll back for going open sided.To get in and out,you un-zip back to the top of the net,then open the stock door.They may seal a tad better than the Honda doors,still lots of open spots.I'm ok with them,should be fine down here in the South.
DSC01288
DSC01289
lee
lee
Village Idiot
2,403
13,608
Springfield Ohio
Shift knob pulls off like the P700 or p1k.
There a few posts around talking about it.
A little heat goes a long way to making them more pliable.
Like point a space heater at it for a bit - don’t use a blow torch that stuff will probably burn.
Reactions: trigger
A
Avi8or
40
81
Mo
I got the Over Armour doors on.Easy install but I did not care for the stick- on velcro strips so I melted small hole around those areas and zip-tied to the roll bar.They will un-zip and roll back for going open sided.To get in and out,you un-zip back to the top of the net,then open the stock door.They may seal a tad better than the Honda doors,still lots of open spots.I'm ok with them,should be fine down here in the South.View attachment 167921 View attachment 167922
I wondered about these doors. They look like they seal better at the forward most point than the Honda doors do. That’s where most of the air with mine comes in.
nctrailboss
nctrailboss
440
1,454
north carolina
I had ordered the Honda doors,but the free shipping went away because of the box size.Ron Ayers called and said the shipping would be $147.I'm happy with these so far.I need to wax the zippers.
