P500 p5 suspension
rocmar
rocmar
4,741
5,777
4 CORNERS
Lol.........I can see the temptation in doing that. I just hope I don't get to comfortable with the new suspension and do something stupid !
You will
I plan on it...
haha
solrus
solrus
1,629
2,511
Montana
I will take a picture tomorrow that should convince you that it is impossible for it to hit the frame.......... as I said before "the shock will bottom out long before it hits the frame"
I would buy too, lets see the final stage and testing . If ok , please fabricate one pair for me. Thanks!
Reactions: Chooglin
Chooglin
@jak9922 I took some pics to show how much angle the A-arm will have when the spring hits the frame.If you look at the bottom shock mounting hole in relation to the angle of the shock , you should see that the shock will have bottomed out long before it reaches this much angle.
I do realize these are the stock shocks and not the Progressive shocks , but it will be very much the same when the Progressive shocks are hooked up..........both shocks have only so much travel before they bottom out !
20161030 084635 20161030 084743
Chooglin
Version #2 of rear shock mount.
I decided to change the way I want these to be made , so I made up another mount.This one will be welded and bolted to the existing mount. This will make for a more rigid mount than version #1.
20161031 193447 20161031 193729
These images show how much angle the shock will have before it hits the new bracket (it is damn near horizonal)
20161031 194156 20161031 194219
Reactions: solrus and Tflynn
solrus
solrus
1,629
2,511
Montana
Do you take angle of compression into consideration. I'm not familiar but is there optimal angle that shock needs to be compressed. Or any angle is fine???
solrus
solrus
1,629
2,511
Montana
Cant wait for the final product to be tested. Are you planning on standard or HD shocks?
Chooglin
I am going with standard.Being that they are adjustable , I can always stiffen them up if I need to !
Chooglin
It would be at a much lesser angle during compression , the pic shows worse case senario.the shock will never reach that much angle.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
with the angle they are mounted you will want the hd its more leverage then the ride they were designed for it not you will be adjusted to full preload in a mth
Reactions: chrisC and Chooglin
Chooglin
Any idea what the spring rate difference is between the HD and the standard ? I thought I read somewhere that it was 100# difference !
Chooglin
Progressive 425 spring rates
Front
SD: part #425-1001 spring rate=100/150
HD: part #425-1000 spring rate=110/160
Rear
SD: part #425-1002 spring rate=225/400
HD: part #425-1003 spring rate=285/485
Specs on shocks
Screenshot 2016 11 01 08 01 21
Reactions: solrus and jak9922
solrus
solrus
1,629
2,511
Montana
