P500 p5 suspension
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
its about 1-1 1/2 inches up from full no shock release no cv binding at all
sthomp54
sthomp54
375
Nice! how much travel does it have now?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
i honestly couldnt tell you but probably not much more then stock just handles it alot better
Nicely done @jak9922
I still NEED one of these 500's. I'll be watching what's next with the rears.
Sent from my iPhone 10s
Sledge
If front shocks are inadequate, wouldn't it be helpful to keep as much weight off the front end as possible?
Underhood storage, bumpers, and winches come to mind.
All useful, but with a downside, too.
Joe
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
the stock suspension is terrible unloaded or fully loaded
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
@Tflynn ;) they are no fox shocks by any means but I think when complete (cough cough next Tuesday ) ill be more then happy fingers crossed lmfao
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,501
3,834
Northern California
I'm sure you will be. Plus it's like you said, now you know Rhino shocks will fit you can upgrade to whatever brand you want. Rhinos probably have as much aftermarket options as RZR's!
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
first full ride and these shock are amazing at slow speed stiff as fuuuuuuk but at any speed like half throttle in 2nd and they suck up everything god i cant wait for the backs to come in
20160511 163001
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
damn @JACKAL not thought coments suggestions on this????? i look forward to your imput the negs and pos
283,012
They look pretty, that is all I can assess from a picture. Is the stroke of the shock different, meaning did you gain additional travel over the 5.9"?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
yes more stroke from the shock also moved the mount about 3 inches lower on the a arm i went from full drop no shock lift about an inch thats where i mounted it
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
also the stroke isnt everything its the valving and spring involved
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
even if i took the stock shock and moved the lower mount lower on the arm it would gain travel even tho lowering the vehicle
JCart
JCart
895
2,023
Kamloops, BC Canada.
So how much clearance from skid belly to ground do you think you'll end up with? I just did the shock recall here in Canada, also put on a 1" spacer but have not ridden enough to really comment just yet.
jrc
