P500 p5 suspension
maybe try kassmaul electric I run onboard air compressor for the fire trucks that build up that high of a pressure to compensate for air leaks in system when trucks are at rest and there 12 volt system and turn on and off when set to desired pressure
That's interesting, I'll look into that as an option when I get back on this as well. Thank you miano. Btw, did you see if you could get me a couple of 10" stainless steel continuous hinges, or any length that I could cut to size??
miano248
miano248
370
398
oceanside long island new york
yes spoke to my vendor yesterday hes gonna see if he has 24inch piece he says there sold as 6ft section and he doesn't want to charge me for that much so he will let me know what he comes up with
Brooks
24
39
Smiths
Someone posted a pic of their articulation.
I'm to lazy to scroll back to see who it was.
Here is a few pics of mine with the JWB mod .
20170124 144452 20170124 144607 20170124 144649 20170124 144755
Great, thanks for helping me out on this. Just to be clear I'm not expecting you to pay for it nor the shipping. Just let me know what he comes up with, and then pm me and I'll work the details out with you. Thanks again.
Brooks
24
39
Smiths
My parking brake doesn't work right now so I rolled down the ramp a little bit.
Brooks
24
39
Smiths
Nice, and what psi are you running in each front shock?
It depends on how your riding. From 70 to 100 psi on the fronts. A little more on the rear.
Like JWB every time I touch it I reinvent it.
I should be done with it this week and I'll post up pics
So you're saying that each shock on the front may have a different amount of air in it, or each pair?
JWB
JWB
2,098
California MD
View attachment 31640 View attachment 31641 View attachment 31642 View attachment 31643
How Cool Is This!! Tell us your opinion of the difference in ride. By the look of the pics, I assume the shocks are 'seeing' each other. Did you install valves to switch them to isolated? Your tires look big. What sizes are you running, and have you had any interference issues after the shock mod? Have you done anything additional to protect the air lines? Don't mean to interrogate you, but it is so cool to see other machines with this mod! If you're talking about the pics with a wheel on the jack- that was me.
Reactions: tjolley_382
Brooks
24
39
Smiths
Right now they can see each other or I can isolate them .
I just got some new vavles in . And with them I will be isolated all the time.
It has 27" tires.
The ride is night and day different for the good. You can float on a cloud or bump up the pressure and ride as hard as the poor little 475 can take you.
It has 27" tires.
Do you mean pump up the pressure while riding, by switching from see to isolation? And what's the advantage of isolation? Do you have one valve per pair of shocks? How many filler points do you have?
JWB
JWB
2,098
California MD
It has 27" tires.
That's what I'm talkin' about!! Can't wait to see some more pics! The pictures you saw were probably the ones on pg 27 in this thread.
Reactions: Montecresto
Sense I'm going to go to doubles in the front now, I have more questions for you. Do I need to add a second Hoke valve, or just pair the shocks up on each side.
The picture should answer this question, and pages 27 & 28 in this thread should answer the previous.:)
That does look easy. Thanks for that. I'll check those earlier pages where I assume that you also discuss how you fashioned a bushing for the stock shock brackets, sense in doubles the air shocks mount to the outside of it.
JWB
JWB
2,098
California MD
You're welcome! Yes, the shocks mount on the outside of the brackets. You'll have to make a little spacer (grind/cut) for the forward shocks to clear the frame. It doesn't take much. Look back a few pages, someone said that they bought tubing that didn't need modification to be used as bushings and spacers, and then drilled the stock mount with a step bit on a ratchet to fit the slightly bigger bolt- a lot easier than the way I did it. (fabbed my own bushings from bar stock)
You're welcome! Yes, the shocks mount on the outside of the brackets. You'll have to make a little space (grind/cut) for the forward shocks to clear the frame. It doesn't take much. Look back a few pages, someone said that they bought tubing that didn't need modification to be used as bushings and spacers, and then drilled the stock mount with a step bit on a ratchet to fit the slightly bigger bolt- a lot easier than the way I did it. (fabbed my own bushings from bar stock)
Ok, I'll give that a look. :)
