Ordered in December and got them in March.when were they ordered? Trying to see when I might receive mine...
14mm for the front.Hope so. Mine came in the other day but I have yet to mount them.
i sent them a question, because on the web site it says black ones are in stock, got a reply today that they should ship in the next few days. After the last trip down to the Salmon river I really need the fronts. The rears are already on but the front end is terrible... We shall see. Ordered mine in Feb so april would be good time.Ordered in December and got them in March.
For what it's worth, their site says silver springs are what they have in stock yet mine showed up with red springs. YMMV.i sent them a question, because on the web site it says black ones are in stock, got a reply today that they should ship in the next few days. After the last trip down to the Salmon river I really need the fronts. The rears are already on but the front end is terrible... We shall see. Ordered mine in Feb so april would be good time.
I am saving the stock shocks for snow plowing. They did a good job when the plow was up, not too much sagging.I never knew there was a choice other than silver or red? The silver ones were beefier if I remember right. I ended up painting my springs black. They've held up alright but occasionally require a touch up.
I have a feeling this is the case as well but went ahead and bought both just in case. I still cringe thinking about the front end slamming into those erosion ditches they cut across those long, mach35 mph trails. Those hurt.Yeah they work fine for plowing bc they're stiff as hell. I've read a couple of times where guys were putting the WE's on the rear first and then springing for the fronts later. The front is where it needs the most help with ride and rebound. After I got the fronts the rear didn't ride that bad with the stockers but I had to have them at that point.
There's gonna be a line, lol... Hopefully nobody things about trying to charge for "Shock test rides"(Look for me begging test rides from y'all at Takeover!)
I hadn't considered it until now. Thank you.There's gonna be a line, lol... Hopefully nobody things about trying to charge for "Shock test rides"
[ How I wish folks with Walker Evans and Elka shocks would specify which model they have. Would be extremely helpful for those on the fence. For some reason, very very few specify which they have ]
I've tried to keep track but no eidetic memory here, best I can recollect . . .
I'm a sad panda . . .
Don't be a sad Panda... life is too short.[ How I wish folks with Walker Evans and Elka shocks would specify which model they have. Would be extremely helpful for those on the fence. For some reason, very very few specify which they have ]
Do you run more preload or compression damping on the driver's side due to uneven weight distribution? I usually ride solo (😢), so I'm wondering if I should attempt to set it up so it rides level with my fatass weighing down one side of it?As far as I know, there's only one WE set for the 500 other than heavier silver springs if desired. Pretty sure there's not many P5's heavier and I went with the standard springs. Set the preload for preinstall ride height and then start clicking. Some guys crank the preload way up but that just messes with wheel camber and makes it ride stiff. Forget where I'm at exactly but want to say 3 clicks from softest setting on front and like 5 in the rear. Once dialed in, I just left it.
You're welcome to test ride my machine but there's other mods that factor into its ride quality.
