P500 P520 Snow plow Question
NatureOne
NatureOne
32
181
Ontario
I have a Warn plow (55”) that I used on my Foreman 500. Does anyone know if I can get an adapter to make it fit the P520?
Raghorn
Raghorn
142
627
Yeah, you "should" be able to buy or fab up a bracket that hooks up from the push tubes to the P520. I would do a little shopping to see if the available brackets appear to line up with your setup.
Reactions: alloutdoors
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
As mentioned above there are likely brackets out there to adapt/use and you might have thought of this already, but I would avoid any bracket that hangs down too low below the machine reducing ground clearance.
rheaslip
22
41
Canada
I had to do the same, making my warn plow for my old 700 work for my 500. You need 2 pieces. The part that attached to the 520. And the piece that attached to the plow. Or have something fabricated. I used the warn site to find the part numbers and then searched the internet and found a site that saved me $100. After it is all done, works great, but I could have bought everything new, from other makers, for the same price of the 2 warn parts I needed.
Aerolite
Aerolite
114
499
Oxford Mills ON
Here's a couple of pics of my 520 with the KFI 60" blade and mount. Not sure if it helps you or not. I can take closer pics for you if you want.
IMG 3676IMG 3713
