Delton
Honda Fanboy
That must be an inside joke cause I don't get it lolAK.. you have to take a picture of your feet for him!
Ya know when you get something and think "how the hell did I get along this long without this"? Well this mod is number 1 on that list. My favorite mod of all. Okay I'm done trying to make you feel better.I think you will be the last person on this forum to install this mod great mod!
I can't wait to get mine rigged up!Ya know when you get something and think "how the hell did I get along this long without this"? Well this mod is number 1 on that list. My favorite mod of all. Okay I'm done trying to make you feel better.
Hey CP, are you still making these kits? Very interested!
Thanks,
Waylan
That is very true. It's been expensive and time consuming with liability so I've gotten out of this. I'll be doing a how too pretty shortly.The auto parts stores sells brake lines, adapters, and fittings. The kit can be made with out cp
You read my mindAre our hondas fittings 10mm x 1 double inverted flare?
You know what they say?You read my mind
the fittings on the controller are not the same as the front splitter on the Honda... I can't remember what they actually were... somewhere on here I posted a picture of the adapter I had to use to make mine work.What are the fitting sizes?
Hook'n ain't easy?You know what they say?
No Not at all. Metric 3/16 on Honda side and standard 3/16 on brake side. They cannot be bought that way. You could use adapters but it's already tight and I tried to do better then that. Plus less joints. Here's the exact lines I've used on the last few sets. You cut what you need off each line then use one fitting from each.use a flare kit and reflange them on. Fittings have to be installed before the lines are bent because of the clearance issues. From O'Reillys View attachment 31304View attachment 31305
It's extremely easy..have you done a how to thread on this yet?
I apologize that I have not yet. Mine is currently pulled as I was planning an electric set based off of the safety neutral switch so a little tough to explain a few things however it's pretty simple. I'll get some pics in later todayhave you done a how to thread on this yet?
