Pioneer 1000-5 letting me down
Bassgoat
7
Mt vernon
2020 Pioneer 1000-5 starts running for a second then shuts down spark and fire only code it blinks Is 13 which is rear injector I've replaced injector the injector harness the fuel pump the plugs checked the coils and wires checked all the relays and fuses checked oil levels checked battery still nothing. It will start back up after the key is shut off and turned back on
Reactions: ChadD
63,987
I need to ask which injector wires/connectors did you buy.
Some of the eBay/amazon specials are reverse polarity.
My research says it shouldn't make a difference. But in our early days making injector kits, we did make a dozen or so reverse.
Most failed to fix the issue. Correct replacements did work.
Bassgoat
7
Mt vernon
That's interesting
Reactions: Smitty335 and ChadD
Bassgoat
7
Mt vernon
That's interesting i did buy them off ebay
Screenshot 20220912 043524 eBay
Bassgoat
7
Mt vernon
I also bought a diagnostic to obd2 adapter and itv won't connect to the ecu so im thinking possibly bad ecu
Reactions: ChadD
13,415
65,766
There are a few reports in the forum of the injector driver in the PGM-FI(ecm/ecu) going bad. New or used replacement fixed the issue.
