P1000 Pioneer 1000 low-end power
F
Forbes
5
6
Carriere MS 39426
Hey guys sorry I know this has been a topic on here for a while but I haven't found the answer I'm looking for yet so I figured I would just ask. I bought a p1k5 put a 6 inch lift on and running 33 bkts went ridding this past weekend to just see what it would do and it does fine in 2wd but it will not turn them in a rut in 4wd
Reactions: Isaiah
F
Forbes
5
6
Carriere MS 39426
I love everything about the bike i just want to know what I can do to get more torque out of it to turn the tires in low range before something happens to it
0608201539 0608201539a
DDDonkey
Look at getting a tune, igr, or portals. I have the silber turbo tune and it helps in the low end, but there are other tunes available. The only real way to recover lost power is the regear with irg or portals.
Here is mine 35’s and a 30% gear reduction.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Im not sure which igr it is but there is a guy running the satv 6 inch with 32 motohavoks with 25% igr and he turns them just fine his speedo is only slightly off. If you go that route you can actually be a little faster on the trails than with portals. But if i was going portals on a 1000 id go 6 inch with 45% and run 37s.
Reactions: Isaiah and Forbes
F
Forbes
5
6
Carriere MS 39426
Nice bike man appreciate the info with the gear reduction how does it ride as far as top speed and can u still run the tranny in auto or do u have to run manual shift
Reactions: Isaiah
F
Forbes
5
6
Carriere MS 39426
Thanks yea I'll probably go with the igr and keep what I got i don't ride as hard I as I used to lol just something to go play every now n then to get the wife n me out the house
DDDonkey
Mine rides great, my top speed is 59 mph but that is plenty for me. I went with portals because I did not want to get into the engine/trans so my shifting is stock.
Schmeg
Schmeg
187
394
Bangor Maine
A bit off topic, but now that we are into summer riding, has the Silber tune made a difference in cab temperat for your buggy?
Reactions: Isaiah
DDDonkey
No not at all, I do hear the fan kick in more often (I asked to have them come on at a low temperature). I need to do a long term review, but I have had no issues with the tune at all. The pioneer has not passed 2 bars on the temp gauge either in riding any where from sea level to 7k feet in the last 400 miles.
To be far I never had a heat issue in the cab but that could just be me. The only time I get hot is slow moving with the windshield on in the summer, I just run the half shield anyway and that helps with the dust.
Reactions: Isaiah and TripleB
Schmeg
Schmeg
187
394
Bangor Maine
My butt gets hot, even with the DEI heat shield in place. I didn’t want to do a bilge fan, so I might consider a tune if that would cool my butt down. It’s that or do a pipe wrap or both.
DDDonkey
I can’t guarantee the tune will stop your butt from getting hot. It’s not a big deal to me so you may want to try to rap in the bilge pump first to be honest.
60,261
I don't think anyone who has done the pipe wrap has seen any benefit.
Reactions: CumminsPusher
Schmeg
Schmeg
187
394
Bangor Maine
Good to know. Looks like a tune or a bilge fan is in order. I’m leaning toward a tune.
Russ989
Russ989
22,641
147,241
^^^^^^^THIS^^^^^^^
F
Forbes
5
6
Carriere MS 39426
Who all is out there that does the igr on the bikes only one iv found is reduction boss are there any other options
aauman88
aauman88
1,091
2,846
Nope Reduction Boss is it and yes they have to modify your trans case for it to work. I went portals and tune. Haven’t found anything I can’t either spin the tires in or get traction and climb out of. 4” 30% portals and PV3 with Morris tune.
Also didn’t like the shifting issue IGR causes
C7EE88AD FF79 4AE8 AFD6 F14A00488858
IGR is closer to 21% and running 32’s effective gearing will be about 3% lower than stock.
Reactions: TripleB
if you are doing a tune use a Talon ECU with IGR solves shifting issues and you can remove the torque management. Then you don’t need to rebuild/change oil in portals, don’t have steering issues or ball joint problems associated with larger tires with the additional forces the portals put on the suspension.
IF you’re in the mud all the time portals are fine but other than that look at IGR and a Talon ECU
Reactions: TripleB
