From the Owners Manual;
Engine Oil - oil drain only - 3.1 US qt. (2.9l)
- drain & filter change - 3.2 US qt (3.0l)
10w-30 API classification SG - no energy conserving or resource conserving on the circular API service label
JASO T 903 - MA
Cooling system - 2.5 US qt (2.4l)
Maximum weight capacity 880lb - operator, passenger, all cargo and accessories
Gasoline - 86 octane minimum
- 3.96 US Gallon (15l)
Spark plug - BKR5E-11 (NGK) or K16PRU11 (Denso)
Tire pressure - 10psi both front & rear
Brake fluid - DOT 4
Front Differential - GL4 or GL5 - no energy conserving labels - SAE80W-90 - 17.2 US oz (510cm3)
Rear Differential - GL4 or GL5 - no energy conserving labels - SAE80W-90 - 5.1 US oz (150cm3)
First service @ 100 miles or 20 hrs - then every 600 miles or 100hrs after that.
JASO T 903 - MA
Brake fluid - DOT 4
