rocmar
HaHa..Still subject to operator errors!
hard to believe
....speed was a factor..
3 yrs.....one crash...Still subject to operator errors!
Ah...you know I am just messing! That still amazes all the mess that ended up on your machine with that one rock! Crazy!3 yrs.....one crash...
alot of close calls
....no injuries
except hurt pride...
get up..dust yourself off....
get back on the...steel
horse & ride some more....
It's all good...Ah...you know I am just messing! That still amazes all the mess that ended up on your machine with that one rock! Crazy!
Thought this Poll might be helpful for Manufacturing dependability or defects questions. Don’t include routine maintenance or accident/abuse repair cost. If you had a significant cost, the model year would be good to know, as well a type of issue, (engine, transmission, electrical, etc). 2017, no problems.
12/3/17... There are 895 forum members listed with P500s. (Thanks @Hondasxs)
I have a 2015, sanded the engine and trannie, 4000.00 to rebuild. 1000 miles. Lots of dust in eastern oregon. I snorkeled the air intake, ran the intake tubes up behind my head. Put a uni filter sock on each snorkel tube, they work as a pre filter. Dual uni filter in the air box. The stock air intake is right above the drivers rear fender and has to be the poorest intake placement ever seen. My friends 700’s have a similar set up. The 1000’s have the intake up front under the hood, like my buddies Yamaha, where it should be. I built the snorkel out of 2” pvc from the box behind the drivers seat and went up with two 1 1/2 pvc pipes. If you are running in a high dust areas, snorkel your 500 or 700, or pay the piper!
Haven't been on in a while. Life is busy right now. Good question though. I have a 2015. I have not had to have anything repaired. Although, with around 20 miles on it, one of the coolant lines slipped off. Got to looking and it never had been clamped. Put a couple of zip ties on it and filled it full of creek water till I could get it back to camp and flush it and clamp it. I am sure this was quality control issues during assemble. Some times the brake pedal goes to the floor, I can pressure wash the underside and the trouble goes away. I have not been able to determine what is going on. I assume something is being pinched off somewhere. I was getting stuck a lot till I put some 26's on it. The 24's were pathetic. Also, water got deep fast on me and drowned it. Winched it out, drained the air box, started right up. Ran rough till I could get rid of water in fuel tank. Went home and snorkeled it. I really think the fuel tank breather line should have been placed a bit higher. All in all, I love this little machine. Goes anywhere I need to go and has been extremely helpful to me both hunting and on my place. One of the most important factors to consider when buying an off road vehicle, do you want it to start every time? Buy a Honda!Thought this Poll might be helpful for Manufacturing dependability or defects questions. Don’t include routine maintenance or accident/abuse repair cost. If you had a significant cost, the model year would be good to know, as well a type of issue, (engine, transmission, electrical, etc). 2017, no problems.
I agree....I think that dude's vote should be eliminated. It clearly states 'not accident related' and drowning the engine in water or sand is clearly negligence on the operator. That engine had to be acting up before he killed it too and that falls under operator error as well. It sways the poll percentage and that's BS! An interesting poll would be how much have you put into your P5 in accessories or mods...then we'll see some dollar signs!
Totally agree with you! The 15 was completely trouble free!Gettin nothing but ....great
reviews...on the "ORIGINAL" 2015
P5..
Just a guess....Honda new..50" SxS
got better QC....
Thanks! I will look at that next time I experience the brake issue.Just a stab in the dark but this often has to do with A-arm guards that hit the brake caliper when the suspension is fully extended/turn. It pushes the piston all the way in and you have to pump the brakes to get the piston back out to push on the brake pads. It usually happens super randomly so its hard to figure out.
