A
So I've owned my 2020 P1000 for only a couple of weeks and have taken it for only one trip. But I noticed it is difficult to move the shifter into LOW when the engine is running (but not when engine is off). In fact, after my trip, I off loaded the Honda and noticed it was also hard to move the shifter from Neutral to High and then Reverse as well. I then ran the clutch adjust sequence that I found on this forum, and now all gears enter easy except for LOW. Doing a forum search, it appears that this may be a known issue with the P1000 with no Honda sanctioned fix. In fact, the Talon may have the issue worse, and a member here has created a gated shifter for Talons that he claims fixes the problem. I created this poll to see what percentage of P1000s appear to have the issue.
