P700 Power Sterring Issue
Carlton
10
5
AL
Power Sterring Issue. My power steering indicator on the dash keeps flickering on and off. I've noticed that the steering will stiffen up at times as well. Any suggestions would be greatly appreciated. 700-4 delux. New to the form. Thanks guys
swsebek
swsebek
2,854
5,835
pa
Sounds like the power is getting cut intermittently. Tighten all the connections under hood and at battery.and welcome to the forum
Carlton
10
5
AL
Are you talking about all the wire connectors or just the one to the power steering pump? Thanks
swsebek
swsebek
2,854
5,835
pa
Should be electric steering. Not like a car. Electric motor that has a control module on top. It sounds like one of the connections is loose.I would get dielectric grease and put on the connections.you have to unhook them and put dielectric grease on the plugs and rebook them back up.
Reactions: Deluxe700 and jinx
swsebek
swsebek
2,854
5,835
pa
I have added on power steering, there maybe something different with yours being stock power steering.but it definitely seems like the power is being interrupted. Maybe at fuse too
Carlton
10
5
AL
I'll take a look at these things tomorrow. Thanks for the responses.
Reactions: swsebek
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Let us know what you find out
Reactions: swsebek
Carlton
10
5
AL
Well I put the dielectric grease on the the power steering plug. When I first did this the problem went away the day of. However, a few days later out riding and the problem is back. Not sure what else to do. I hate to take it to a dealer if it's a simple fix
Neohio
Neohio
Beast of the East
14,572
73,598
Painesville Ohio
What other loads are you putting on the machine when it flickers? How old is your machine and its battery?
Did you check and clean the positive/ground connections at the battery?
Check and clean the main chassis ground from battery.
A friend has a 17 700-4 deluxe. His has power steering flickers as well in the winter when using his snow plow. I told him to change the way he pushes snow, activating his plow while turning is too much load on his factory battery. I am in the middle of talking him into a full size battery under the seat to help this issue.
Carlton
10
5
AL
No loads are being put on. I checked the terminals and made sure everything was secure. The 700 was bought new last November. The main chassis ground location is that on right rear in front of rear tire on the frame? I'll have to check that.
Neohio
Neohio
Beast of the East
14,572
73,598
Painesville Ohio
Honestly, I have no idea where the main chassis ground is on the 700.
If these don't help you issue, your battery might be failing. Should be easy enough to have load tested at any parts store.
I believe one of them is in front of a rear tire. It’s been a while so I’m not sure on which one I think it’s the right rear.
Carlton
10
5
AL
Got the battery tested and the battery was bad. Replaced it and as of now no issues whatsoever. Thanks for the help. Would have never thought it was the battery.
Reactions: dhcross61
dhcross61
6
5
ARKANSAS
Got the battery tested and the battery was bad. Replaced it and as of now no issues whatsoever. Thanks for the help. Would have never thought it was the battery.[/QUOTE
I had the same issue and it was also the battery.....I told Dealer I had read this post and asked him to check my battery. He said he had another one that just came in and thanked me for having a possible solution cause he did not know what may be the cause of the intermittent light and power steering.
Reactions: Carlton
Carlton
10
5
AL
Good deal. I have not had a single issue since I replaced the battery. I knew it had to be something simple do to the fact the 700 was less than a year old at the time this was going on and had only 120 or so miles on it plus never ridden hard at all. Glad this fixed your issue too.
Reactions: swsebek
