P500 Pre purchase questions
Buford
Buford
362
586
U.S.A.
Forgot another advantage of the Mule SX XC, it already has 26" radials stock.
Russ989
Russ989
22,645
147,291
I looked at one when I bought my p500, they are pretty good but the Honda has a better drive train in my opinion. Either one would fit the bill, but I still prefer the Honda of course.
Reactions: 500oneer
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
I’ve owned one and agree with the utility aspect and wish I had something like that but with a little more gitty-up-and-go. I did not like the choke, and the lack of power, especially if you came up on any incline. I would like be more inclined today to look at the Kubota RTV 400 or likely the 500
U
ukrkoz
12
PacNW
Ah, yeah. they do have FI one for $500 more vs P500. I am not sure about 401cc engine though... sounds under-powered, though towing capacity is higher than P500. I like CVT though. Should shift smooth. And 3 yr warranty.
906UP
906UP
15,015
142,633
da Yoop
It's hard to beat the Mule for pure utility, we had one at the power plant when I worked in Texas. It's about as far from a sport/trail rig as they get but when it comes to getting work done it's the ticket.
Reactions: alloutdoors
Buford
Buford
362
586
U.S.A.
They definitely don't accelerate quick and top out at 25. But I'm sure that they have enough power for a property use machine, especially using the low range. The CVT is convenient for sure, and I can't say that I've ever had to put a belt on one ( older 610 or the SX) in the almost 5 years I've worked at the dealership.They maybe ride a little stiffer than the Pioneer with only having 3.1" of suspension travel, but would be more stable on sidehills and better for pulling trailers with the straight rear axle.
The steel dump bed on the Mule would be alot handier than adding the stationary plastic cargo tray that Honda sells for the P500, or one of the aftermarket (Strongmade) beds.
T
Tstover
141
398
Central PA
Another SxS to consider for that type of use is the Kawasaki Mule SX XC. In fact, I think they might be a better unit for your intended use. A few advantages they have over the Pioneer 500 is : all steel dump bed, turf mode / unlocking rear end, lighter steering, alot more steel used in the construction. They also added optional fuel injection for '19, which is the only way to go in my book (only $600 more).
I'm considering selling my zero mile '15 Pioneer 500 and getting a new Mule SX. It's obvious I'm never going to do any recreational riding after having mine over 4 years and never driving it. And I think if I had the Mule I'd at least use it for chores around the place.
Now the Mule ain't going to win any races with a 25 mph top speed if that's an issue.
You have a zero mile '15, and you might sell? I've been looking for a few months, half heartedly, but still looking. I'd be interested, depending on how close to PA you are. And the price of course.
Buford
Buford
362
586
U.S.A.
I'm out in the wild west, probably well over 2K miles away so I'm sure it wouldn't be feasible for you.
T
Tstover
141
398
Central PA
Well, I did drive over 500 miles to pick up a 9 year old KLX 250!
Backwoods
Backwoods
37,509
374,233
Douglasville ga
Here is the brochure for Kubota 400/500 RTV to consider as well. Personally, I would look at the 500 with liquid cool, hydrostatic drive, etc., and Kubota's are known for utility/work, https://www.kubotausa.com/docs/default-source/brochure-sheets/rtv500.pdf?sfvrsn=e197ac2b_4
I have a Kubota RTV 900 diesel I have had since new in 05 great work machine you can't tear it up it has a hydraulic dump bed I highly recommend it for a work machine but is horrible to try recreational riding. It is loud,27 is top speed and weighs a little over 1800 lbs.but it will drag a Pioneer out of anything.
ShotgunClay
ShotgunClay
172
594
Founders Ranch New Mexico
I was seriously looking at a RTV 500, but then my P5 showed up at the dealer with 170 miles on it. For what I'm doing, it's superior in every way except bed carrying capacity (but we have several sizes of trailers I use).
Reactions: Gassygordo
Mudslyder
Mudslyder
Central Ohio
I have a family member that drives all over the country doing pick-ups and drop offs of small loads like this. He plans a route to maximize efficiencies so his prices are very reasonable. If that helps in making the deal let me know and I will get you his contact info.
Reactions: Mudder and Chooglin
Buford
Buford
362
586
U.S.A.
I'd probably be lucky to find even a local buyer since I won't sell mine for anywhere even close to book price.
