BigOl3... I like your setup...
it is very clean and a simple, elegant solution to relocating that intake. But to me, it is not making the best
View attachment 84608 use of the space I want under the hood... look at all this wasted space...
I am thinking of cutting off the intake tube above the hanger bracket... using a fernco rubber adapter to remount the cut off section with the bend facing into that cutout and come out in a prefilter under the dash.
I am also looking at the flexible tube:
3 INCH ADJUSTABLE FLEXIBLE SHORT RAM/COLD AIR INTAKE DUCT TURBO TUBE PIPE HOSE | eBay
That stock tube has an O.D. of ~71mm, an I.D. of ~65mm and a wall thickness of ~3mm.
This flex tube has an I.D. of ~72mm and could be used instead of the fernco and old tube section. I am buying one to try. The built in brackets are an added bonus.
FredD
