P500 Pro Armor 4 speaker sound bar UPDATE. ....
rocmar
rocmar
4,741
5,776
4 CORNERS
Needs a thump box.....there's leads
for that.... so got 10" KICKER BOX
in the Mail.....
182,153
Yeah...Bad Ass Roc!!
So...where are you putting that sub?
Is it powered or are you adding an amp?
Nothing like climbing a hill or going through a mud hole
with Uncle Ted ' Stranglehold ' rippin at your ears!
Reactions: rocmar
rocmar
rocmar
4,741
5,776
4 CORNERS
HaHa.....
did that this past
weekend...
No...Bro got plenty of power
...needs bang....Thump
....sounds great when
your about 6 ft...... &
Beyond....
inside the cab....loud
is not so good...
It's non-powered
400 watt ...10"
KICKER Thump Box
going between seat
in the back....
if measurements are
right....
rocmar
rocmar
4,741
5,776
4 CORNERS
Don't wanna draw so much
power....I need another...
battery. MORE $$$
I hooked my bass speakers
from the house...&
Rattled windows.....crisp
...clear..
Reactions: trigger
182,153
HaHa.....
did that this past
weekend...
Beyond....
is not so good...
It's non-powered
400 watt ...10"
KICKER Thump Box
going between seat
in the back....
if measurements are
right....
It's funny you say that, mine sounds better standing away from the cab too.
I put mine in the toolbox to be protected from mud and water.
Cut in multiple vents to let the sound out.
Bassey as hell when you open the toolbox.
Reactions: rocmar
rocmar
rocmar
4,741
5,776
4 CORNERS
...I also installed that...
noise/heat Barrier. ..which
cut the cab noise at least
in half....stopped heat totally
Reactions: trigger
rocmar
rocmar
4,741
5,776
4 CORNERS
I need to do that too...
BTW, pics or it...
...mounted it upside down to
keep it tucked up...
20160521 121331
Reactions: trigger
