Done, ordered front Rhino shocks from Walker Evans !!!
So my logic behind of this is:
If I want to upgrade your ride a bit , then I would just buy ONLY FRONT new OEM Honda shocks - 51400-HL5-C21, since rear already adjustable and might sit your P500 a bit taller at the rear , since new front ones drop a bit, from reading about new shocks
BUT, if you want BETTER ride and , I have two true "shock pioneers' now to attest then , you need to get aftermarket and do mods.
I thought and Chris agreed that most of the work and comfort of ride ~ 75% is done by front shocks since they tackle the obstacle . So I decided to install only front Walker Evans shocks for now, since the mod is very simple and could be done anywhere who can perform welding job with front lower shock mount.
And as HUCK mentioned, I would use his method of "uneven" tire pressure, rear lower , front higher.
I will still keep 6-8 PSI - front and drop rear from 6 to 4 psi if needed, but I think 6 PSI is good for me now. But lowering pressure might help to compesate rear OEM shocks to keep up with fron racing Walker Evans shocks.
But to me most of bouncing comes from the front, that should improve with racing shocks.
Don't know , will test ride and come up with optimal PSIs. May be later in the winter will install rear WE shocks.
To me if I had a choice to change P500 for 2018, three main things I would do standard/optional from the factory:
1. Power steering
2. Fox/WE etc shocks
3. Full cab
