P1000m5 Put sealant on beadlocks?
Wareagle73
Wareagle73
Hartford KY
Hey guys. I’m sure there is a thread already that I couldn’t find. I have itp dual beadlocks on 30” carnivores. I was extremely careful trying to make sure all seals were seated, bolts were torqued correctly, etc. out of the 4 I have 1 that leaks slightly around the bead on the outside. I am going to disassemble them and put anti seize on all the bolts. (I didn’t do it the first time). Should I buy and put the rubberized bead seal on the rim or the ring when I put them back together??? If any at all. Any suggestions on the exposed bolt threads between the ring and wheel?!!!!
Also I am installing elka stage 4s. Any suggestions on the shock settings would be greatly appreciated. They came pre set from elka set for 2 passengers and 150lbs payload. P1000-5
Reactions: Zax185 and TxDoc
TxDoc
TxDoc
2,090
7,009
TEXAS 🇨🇱
photos.app.goo.gl
FWIW... TIREJECT is more like water and will seal rim leaks. It will harden the glue with plugs. Slime will dissolve the glue with plugs. It will seal dry rot cracks and 1/4" holes with ease.
See what bead lock owners say they do.
rickoshea
can't speak for the beadlocks,but set the shock ride height to factory then play with the settings.i'm constantly changing mine for different terrain.it's not a set it and forget it kind of shock.my starting point is usually 16> from full soft and up/down from there.
