P1000 Question about satv a arms
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
So I’m looking at getting the super atv a arms but have some questions dose everybody do front and rear? and dose the a arms come with bushings in them already? I know they don’t have ball joint unless you select them to, thanks in advance
66,813
Hi,
Depends on your needs.
For 30's you only need fronts.
For larger, you need both front and rear.
Yes, they include the bushings.
I would recommend ball joints since it is now an option.
I would NOT recommend re-using the current ones.
But you could if you are good with the press.
SuperATV
SuperATV
1,348
9,377
Madison, IN
www.superatv.com
I'd like to place an order for the rear arms.
Sent!!!
Giphy
  • Haha
Reactions: JenElio
