P500 Quick question about the rear U-joint?
43,057
My rear output shaft u-joint boot is torn. I'm tempted just to remove it and run the bare u-joint until the joint gets play, which may take years, esp since its only $50 or so. My only concern is getting crud in the splines on the shafts and causing wear.
I know they are sealed with an o-ring from the outer ends, but are the splined holes for the shafts on the u-joint assembly itself blind, or open to the inside? Can't really get a good look without tearing the rest of the boot off.
I've had this part off of a 700, but honestly don't remember if it was open.
TIA.
178,789
TIA.
@Montecresto might know, I think he had a torn boot on the rear?
Reactions: DG Rider
jwfirebird
jwfirebird
927
1,446
western ny
not going to be years if the grease is gone
there was a guy on here that sealed it with boot repair, seemed to last
personally have just took the shaft out and changed it normally not that big a job, probably 20 for the boot
43,057
Answered my own question this morning. Went out to the machine and took a second look, and there, clearly, was the spines sticking out on the shafts on the inner sides. Looks like a boot for me...
