P1000 Quick release steering wheel
322,785
Same steering wheel on all the Pioneer models.
Is the stem length the same between wheel and dash housing?
Reactions: jinx
lee
lee
Village Idiot
2,411
13,650
Springfield Ohio
The steering wheel is the same part.
Also the paddles for the shifting are almost the same (p1k has some machining to add a detent, paddle shape is the same).
So probably but I didn't check it.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
I did forget that I ground a little off of the hub adapter so @Neohio you memory was right but no machining at all. Wanted to make sure info was accurate. This was done to get paddle spacing to steering wheel correct. There was a lot done to Puddle Jumper in that month so memory was off :)
P1000 - Cumminspusher-the New Ride
Again CP.. thank you!
I just trimmed the NRG piece. My wheel should be here in the next couple days.
322,785
Absolutely. Well worth doing the mod. Very curious what steering wheel you chose but wait till it’s on to post:)
I found quick release hub from DragonFire Racing that will fit the Pioneer and wonder if any forum members have this device on their P1K. Could this be used as theft deterrent if the steering wheel was removed when it was stored or traveling to and from rides. I have good insurance but I'd still rather not lose mine to thieves.
Gotta be careful about quick release steering wheels....:D
Jimmie Johnson 'completely shocked' steering wheel came off in Good Sam 500 qualifying
Reactions: mjn and Mudwing
