Talon R turning radius improvement?
Sandfreak
23
Oregon
Did anyone come up with a way yet to improve the turning radius of the R?
Bigshow
Bigshow
162
729
Not that I have seen. But I was wondering, since the X and R use the same chassis, but the R a arms are sweep forward for part of its longer wheel base. This puts the CV joints on to much of a bind to turn the wheels as sharp as the X. Could we make X geometry a arms (- sweep) that are R length and that would allow the front wheels to turn sharper as the CV would not be on as a sharp of an angle with the axle straighter? Plus it would shorten the wheel base a little which would help with a tighter turning radius also. I do not have either machine to look at this.
L
Lovetorque
68
80
Columbia falls mt
Oddly enough Honda shows the four seater which is even longer than the r yet they have the Same turning radius I have a talen R model and I think the radius is just a little bit pathetic
jasond
jasond
220
350
Indiana
I'm also waiting for someone and/or the aftermarket to address this issue for the R.
I had read on a Facebook Talon group (so take it with a grain of salt) that Hess Motorsports had something in the works for this issue, but I haven't seen anything come to market as of yet.
200X
200X
5
10
Northern Utah
I'm new here. Looks likes lots of good discussion. I am looking at getting a Talon X and have been unimpressed by the turning radius. The specs say something around 17 feet. That seems HUGE. I'm not sure what the turning radius is on the SXS that I currently own a quick search says that it is less than 8 feet. That's a big difference. Is it really 17 feet?
NTCPrezJB
NTCPrezJB
President of #NTC
100,709
899,716
Canton, OH
The turning radius of a 400EX is 10 1/2 feet if memory serves. What SxS is under 8 feet?
200X
200X
5
10
Northern Utah
I have a Commander. 8 feet seems low, that's why I did a disclaimer in my comment about a "quick search". I did notice it when I test drove the Talon. Thats why I'm asking.
Reactions: NTCPrezJB
NTCPrezJB
NTCPrezJB
President of #NTC
100,709
899,716
Canton, OH
The little P500 is at 12.8 feet. I've never been around a Commander. It could turn that tight. I'm like you and would be surprised though.
jasond
jasond
220
350
Indiana
As I was typing this earlier I figured I'd reach out and see if I could get any good info directly from the source. They were very quick to respond and here's what they had to say. It's not a definitive "yes we're going to address the R's turning radius", but it sounds like it sure is being considered in addition to other accessories:
Hess Motorsports Response
320,061
Those are big numbers. Tough to get around here in many places. The Pioneer 1000 is under 14ft with a 5 seater. But using the upper full length skid plate it’s like half lol.
I’m hoping someone comes up with something for the X too. I think part of that might be the locked rear end though.
Bigshow
Bigshow
162
729
IDK that the solid rear end makes that huge of difference. My 14 Maverick XRS DPS has a solid rear end and though I can not find a turning radius spec for the Mav, it does not take a parking lot to turn around. Now the 14 Maverick wheelbase is only 84.4" and that helps vs X at 87.6" and R at 92.7" of the Talon. I still think the answer is a negative swept front a arm on the R.
320,061
It is a very noticeable difference on mine for sure. When traversing super tight trees I try to run in open diff when traction allows.
Now with that said I did switch to forward arched a-arms and with that miserable steering limiter that comes with arms removed it’s not been bad. Lost a little bit but not near as much as I would’ve thought.
Obviously forward a-arms changes tie rod angle for the negative. The straighter across the more push outward.
Im just wondering if the Talon wasn’t limited a bit from factory to keep from breaking shafts. I’d be curious to see steering angle between the Pioneer 1000 and the X.
Reactions: Bigshow
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
Well there that is x vs r and that makes sense for axle life. Im wondering the difference in stroke between the X and Pioneer rack? Those two are closer related I would assume.
Check the part numbers?
Bigshow
Bigshow
162
729
I come up with my idea for negative swept front a arms for the R from reading your post in those threads. I think a -2 a arm on the R and the X steering gear, should make the R turn tighter and not hurt the CV joint. This would also straighten tie rod angle and also shorten the wheel base from 92.7" to 90.7" which would also help steering. I do not think the little bit of shorter wheelbase would hurt handling in the woods.
CP I figured there would be some difference between locked and open but not alot. With the gear ratios not much difference between the P1K and Talon, possibly put a P1K rear pumpkin in the talon?
Reactions: CumminsPusher
320,061
I would assume that shorter wheelbase on the R nose might actually dig a little harder too. Might be better then just turn radius with the rear engine.
I do like the open in certain situations. Didn’t figure it would matter till we went from the P700 to the 1000. Wish the Wolverine had it.
I’d personally like a manual lockup while keeping the i4wd front.
Gotta feeling we will see some cool stuff coming from some solid minds. Been digging the people that can’t leave well enough alone with the Talon like what happened to the Pioneer. Makes a better machine for the individual
jasond
jasond
220
350
Indiana
The pedal on the right works wonders for improving the turning radius.
That, unfortunately, isn't always a viable option in tight wooded trails here in the Midwest and East Coast. Trees are very unforgiving when challenged.
320,061
Lol, same here. It was a funny statement though
Reactions: jasond
