Just wondering if everybody else jug is so for off center from the inspection hole. Even if my cables were not there, the cap can not be removed without pulling the whole jug forward, if adding fluid.
Mines off as well...has rubbed a spot through the camo...i tried tweaking the mount but not much movement. A guy could shim the mount out with a couple washers on the bottom hole a bit to bring it more to center
