Rear Axles
Derek1000r
24
83
Hello,
I have a 2019 Talon 1000r and started having a clicking noise on the right rear. Cv noise, so I thought I would upgrade axels, so I bought the blue Rhino 2.0. Since installing them I keep getting diff leaks, out of the axel seals, speed sensor o ring, and filler o ring. Seals were new.
Tried two different viscosity’s and synthetic VP racing. Still doing it. Vent tube is not plugged.
At the same time I also went to a 32 tire.
But thinking more of the axle issue..
Anyone having this issue???
906UP
906UP
14,241
134,968
da Yoop
Over filled the diff? I know not likely but it's worth checking, they don't hold much oil
115,312
How many miles? And how many on the original axels?
New axels dont cause diff leaks btw. Never seen it. Only with worn old ones causing seals to abnormally ware then with new axels here comes the leaks
Derek1000r
24
83
Just looking to see if anyone has had issues with these aftermarket axels, or running 32’s
and since I did both at the same time it’s hard to tell, my old tires were 30’s
115,312
900 on the old ones, and 1200 over all miles
Are they Hard miles, ride swamps? Very low milage for your Axels to go bad unless you Ride hard.
The rhino 2.0’s are good axels. Have them in my Pioneer. Havent had to replace them in my X2 yet. But I will with 2.0’s when i need them. I have 32’s on my X2 and 30’s on my P1
208,725
You talk like my wife, she worshes clothes and wares clothing most of the time and she's head of the english dept. at school.
Derek1000r
24
83
Ya, I heard of that. Mine seep a little, they have a up graded seal now.
but my rear, is leaking from o rings as well
Derek1000r
24
83
It’s a heat issue, axels and cv’s are beefy on the 2.0’s
But you would think I would get some fluid out of the vent tube, which I’m not. Just out of the o rings . Seals
Reactions: Smittyp
115,312
We don’t do swamping, desert only. Kinda hard, that’s why the original axel started clicking
Little forum etiquette here not being sarcastic.
when Replying to another's post, hit the “reply” on there post then your comment to it underneath. For 2 things, #1others know what your talking about, And #2 so the poster your replying to gets a notice. Most of us dont subscribe to Threads unless its our own cuz our phones with blow up! Lol. So we may not ever see that you replied otherwise.
Reactions: Smittyp
115,312
Change the O rings out then. If there new, get some more robust ones
Derek1000r
24
83
Gotcha sorry
