![rlutech](/data/avatars/m/1/1426.jpg?1543880325)
It looks completely sandblasted. Bare steel.
Is it toed out or in ?I’ve noticed that the front side of the rear control arms are very rusty. It appears that the front tires must throw a lot of debris directly into the rear control arms, shocks, and springs. Anyone else notice this on their machines? I’ve never had this on any other ATV before.
Powder Coating. One of the worlds greatest scams.
I wonder if you could rhino line those areas when you're done riding for the season. Stuff takes months to cure but when it does it's tough.
@Buford That doesn’t look like the coating started peeling that looks like it’s been blasted by rocks.
I don’t know what coating or prep you think will hold up to that.
I hadn't pulled up the pic and looked closely at it, and I agree that's what it looks like. But there are several cases of paint peeling off of areas on the frames, roll bars, racks, etc. (atv's and sxs's) that haven't been blasted with by any rocks. Spots that once moisture gets underneath it goes to work and big pieces will peel off. Metal that's treated or blasted and has a good quality primer, preferably epoxy, would not do that.
Besides the previously mentioned catalyzed bedliner material, there are some real high quality automotive paint products that I will bet money on that can hold up significantly better that what Honda is using in areas such as that control arm.
I am not above criticism when it’s due but blasted by gravel is abuse few coatings that are economical enough for mass production are going to hold up to. There are some EXPENSIVE specialized coating that will hold up to more abuse but gravel I think would still beat them away.
Good point. Over time not much will hold up. Have you ever seen how moving corn and beans eat through metal?
It'll eat clean through a lawnmower deck.There are guys who ride grassland and it’s amazing how much paint and powdercoat grass will remove given enough time.
Not at all.I’ve noticed that the front side of the rear control arms are very rusty. It appears that the front tires must throw a lot of debris directly into the rear control arms, shocks, and springs. Anyone else notice this on their machines? I’ve never had this on any other ATV before.
Do you ride gravel roads? At faster pace?Not at all.
