Rear diff very noisy & pops
A
Ahanson
I drove his and it made a popping noise Honda sent the axles but the rest of the rear end will not come til mid February I suspect a redo of something in the rear end. No news on what was making the noise he may get anew case also news to follow in feb
A
Ahanson
It made the noise going slow or fast no problems with mine yet changing the oil is a pain
275,662
Thanks for the information, we are always sharing information among other owners of both good and not so good experiences with our equipment. Please let us know how it turns out. Meanwhile feel free to post some pictures of your P500 and rides you have been on. We all like a good adventure story. :D
Reactions: Hondasxs
William
William
1,442
2,887
Flowood MS
Mine had the roaring noise but no popping... Royal purple gear oil and I don't even hear the gear roar. I'm just having problems shifting from 1st to 2nd when the motor is cold.
A
Ahanson
Honda finally sent a complete new rear end and extended his warranty by 3 months. The short stub axles were toast also. It has been at the shop since December of 15.
Hondafreak
5
Rienzi Mississippi
Mine made all kinds of racket until I changed rear end oil to Mobile1 75w 140. Mine made a rattling sound when holding it at a steady speed and letting off the gas a little. After I switch oil it's fine now.
Reactions: Montecresto
W
Wyoming
Wyoming
Nice to see Im not the only one with this problem. I have been after my dealer for a repair for this issue since last may when we bought a new 500. So far the only answer I have got is that they all make that noise and its normal. B.S.! Im a mechanic and that is definitely not normal Its trying to come apart!
I think its the loudest during deceleration. We also have the rear windshield and this seem to magnify the already loud noise. Almost makes you not want to drive it for fear of being stranded. Its going in for its first service soon so I will find out if they have any updates, if not I will try the oil trick.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
the oil is not a trick the noise you hear is the play in the rear diff putting in a better heavier oil stops the problem
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
i had the same noise u have now i changes the fluids and its gone and i put my p5 through hell
Z
ZZ15
19
I can't find the spec's on what type the rear differential is, locker, limited slip or open. I use to get a noise like that in my 700 Rincon. Be driving along and all of a sudden a loud pop when letting of the gas. I changed the rear fluid to a 100% synthetic (non-Honda) and the noise never returned. It sounded a lot like the Limited Slip Differential in my Firebird when the clutches were sticking. This is what I used Severe Gear® 75W-90 Synthetic
Has anyone tried changing the fluid?
Z
ZZ15
19
Then I would not be using oem branded gear lube, its lacking or uses weak additives or it gets contaminated too easily.
Z
ZZ15
19
Don't think I would use a 75W-140 if a 75W-90 or 80W-90 is recommended. Thicker lube makes the gear case run hotter because it causes more friction.
That's a viscosity used in heavy duty trucks like the Ford SDF350 dually.
Here is a Severe Gear® 75W-110 Synthetic Lube
ehart814
ehart814
1,697
3,859
NWPA
The rear "diff" isn't as much a "diff" as it is a spool... It's locked all the time - both wheels spin the same speed 100% of the time. I see others use the 75w-140 with good luck, but I chose to stick to the grade recommended by the book. I'm an Amsoil dealer, so I used the ATV/UTV gear oil they offer now. 80W-90 I believe... It did quiet the noise a bit. Between the fluid and working the machine very hard, pulling a disc, trailer, etc it has quieted down a lot now. I really do think that they need some time to break in. Others here have noticed the noise quieting down after getting some miles on.
A
Ahanson
New rear case, new axles as they were chewed up inside the case, no noise now but it took 3 months for the parts to come.
Call the Honda rep if the dealer is not taking care of your problem
