P1000 Rear Differential Adjustment
lee
lee
Village Idiot
2,327
13,031
Springfield Ohio
Fyi, 22 is adjusted differently. We don't have the procedure or a video
For the flux capacitor delete system, put the levers in Park and Turf mode.
Make sure the rear diff is locked (jack up a tire and try to turn it)
Pull the plastic cover off the rear diff (left side).
Adjust the nut like the front diff cable --> tighten the nut till the cross barrel just touches the end of the slot in the diff lock arm.
Back the nut off 1/2 turn.
Put the cover back on.
Done.
lee
lee
Village Idiot
2,327
13,031
Springfield Ohio
Almost forgot the pictures:
97997 4c796e18090d67bda99f63358cf6a1e1
97996 253d385dfa322e60130c0db2aeca2f1e
K
Keithcriley
London ontario
Help please I have 2021 1000-3 had same issue stuck in turf. I followed the video and it was working fine while I had it up in the air. Soon as I put id down took it for ride was stuck in turf. Any idea why?
  • Wow
56,672
Are you sure it's stuck in Turf? Mine will often not show the 2WD Lock indicator on the dash for a bit but it still locks. You may need to adjust it just a bit more in the lock direction if it isn't actually locking.
Jerryg
Jerryg
10,491
85,187
NEPA
That can't be, I have been told by many here that turf mode is not at all a weak link in the rear diff.
Must be another problem somewhere else.
56,672
It absolutely isn't. It's mechanical and needs to be adjusted just like anything else with a linkage.
