Jshell3
I made a short video last night about adjusting the load on the rear shocks without using a spanner tool.
Channel locksGood idea using a pipe wrench instead ... you would need a 3 foot handle to be able to turn that using a spanner.
...if you removed your sway barWell, I've had a chance to ride Blueberry since the rear shock adj... and 2 clicks on each side stiffened things up. I'm glad I didn't go all the way. It's noticeable in a good way.
It's not as soft as it was before, and feels more like the ride I remember on day one.
So this is a definite recommend for anyone that's added weight.
He's a Doctor...Where does one get some of those work gloves?? Lol..
Did....if you removed your sway bar
that has alot to do...with it feeling
soft & Loose.....
just sayin...
Thanks! Honestly, I was reading some posts about it... hopped up at about 11:30pm to just run out to the shop and give it a try.Thanks for the video J. I know there are pics out there but video is always better.
I used a pipe wrench and went two clicks as well. Haven't bottomed out since.
Harbor Freight. If you ever start using them, you'll never stop. Seriously.Where does one get some of those work gloves?? Lol..
Purple?? Do you wish your 500 was purple too?Harbor Freight. If you ever start using them, you'll never stop. Seriously.
I reload ammo, too. Avoid lead poisoning...
I just wish they were purple.
