Rear stabilizer bar
T
Talon555
Anthem, AZ
  1. Talon X4
I have a 2020Talon 1000 4 seater
1 year old. Rear stabilizer bar broke. Anyone else have this happen?
C5B335CB 11DF 4D59 9CF5 AA6BAB470CF4
  • Wow
Reactions: Montecresto
SLOWPOKE693
SLOWPOKE693
1,848
7,324
Somewhere in Texas
Get yourself an Eibach sway bar and never have a problem like that again. They are adjustable and the price is decent. I run one on my racecar and have zero complaints or issues with it.
Sheetmetalfab
Sheetmetalfab
2,152
13,464
Alaska
Alot of performance sway bars are hollow. Being solid doesn't automatically mean ultimate strength.
The fact it sheared off, plus the fact it’s hollow, does mean that it’s chintzy though.
I had assumed they were solid.
Brazula4life
75
Florida
Good to know that they are hollow, I actually upgraded my few weeks ago, pricey but changed the car completely. Its a torsion rear sway bar with 5 adjustments this thing is heavy and solid. It's from Double e racing. The cool thing is that the more body roll you throw at it the stiffer it gets, I do rallycloss so far has improved my times drastically.
20210701 184015
SLOWPOKE693
SLOWPOKE693
1,848
7,324
Somewhere in Texas
Be aware that those are well known to break. I was going to buy one for my Talon but after seeing and hearing about so many snapping off at the necked down area of the bar I decided to go with Eibach. It would suck to lose a race because the bar snapped and the arm and remaining piece of the bar took out your tire or possibly your suspension if it gets jammed up in the wrong place.
Brazula4life
75
Florida
I actually haven't heard or seen that at all, this thing is solid and very heavy, most brands are hollow
SLOWPOKE693
SLOWPOKE693
1,848
7,324
Somewhere in Texas
A little stiffer sway might be in order. or designing one for the front...
Go with the Eibach sway bar. Huge improvement over stock and it is adjustable so you can fine tune it for your riding style.
Front sway bars have been tried on the Talon under racing conditions and they suck. It completely screws up turn in and makes the car handle funny. None of the cars or teams including the Pro's (Honda, Yamaha, Polaris and Can- AM) at the track run front sway bars for this reason. Weight transfer is key to turning hard on loose surfaces. Sway bars prevent that from happening.
My car with an Eibach rear bar set to the middle position...
IMG 0598
851A9178
Brazula4life
75
Florida
What suspension and tire wheel set up are you running , looks lowered
Reactions: Remington
SLOWPOKE693
SLOWPOKE693
1,848
7,324
Somewhere in Texas
-Stock shocks built and tuned by Double E Racing out of Louisiana.
-Tires are 27.5 x 8 x 15 Hoosier SxS tires
-Wheels are 15 x 8 GMZ Casino beadlocks
5,406
24,778
Tire pressures? No reply necessary if it's a tuning secret.
